Question about RIM BlackBerry Storm 9530 Smartphone
My screen does not rotate when i rotate the phone, can anyone help?
    Sergeant:
  • 322 Answers
Try reformatting it and tell me when it is resolved.
Posted on Jul 02, 2009
Screen won't rotate
Screen won't rotate at all - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Galaxy S3
Aug 4, 2012 - 25 posts - ‎22 authors
So far this is the absolute best phone I have owned hands down. I have a small but annoying problem of the screen not auto rotating, or rotating ... Samsung Galaxy S6 Screen rotation won't work
Apr 18, 2015
Note 4 problem - Screen won't rotate
Apr 12, 2015
S6 Edge - Screen rotation does not work properly
Apr 10, 2015
Screen won't rotate
Jan 3, 2015
More results from forums.androidcentral.com
Jan 17, 2016 | Tablets & eReaders
Screen will not rotate and the lock is turned off
Hi
... when you say the "lock is turned off" ... do you mean the screen locking after a set amount of time?
Allowing a screen to rotate is driven by the application. The application has to be developed to allow screen rotation. In some cases like the app from SpeedTest (which you can find on the App Store) only functions in "portrait" mode while the home button is on the bottom ... however you rotate the phone ... 90 degrees or 180 degrees, the screen stays fixed.
Hope this helps,
Ron.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Nov 18, 2014 | Apple iPhone Cell Phones
My auto rotate screen didn't work normally
I just bought a new HTC Wildfire. Even though, I checked the box under settings/orientation to have the screen rotate when I turn the phone, it does not rotate. It will with a photo, though the size of the photo stays the same. Can anybody help?
Mar 15, 2011 | HTC Wildfire Cell Phone
Hi Rajessen here,from mauritius! can i know if have a software for N70 to rotated the screen????
Would say yes and no.
If rotating the screen just for video playback then i will say you try divx player for symbian and if not , nut just to have the screen itself rotated during usage then i am afriad there is no such software.
This has to do with the fact that the phone is locked for a single screen resolution during normal usage.
Let me know of you need more help.
Good luck
Nov 11, 2010 | Nokia N70 Cellular Phone
I have a Toshiba Portege 3500 with rotating LCD screen, my problem is that I can not rotate the wiew of the screen. The settings were changed, and now I can not rotate the view again. Thanks for your...
Do you have Windows XP with servicepack 3 installed? If so then there is a known problem with the screen driver and XP sp3. Go bakc to SP2 and reinstall de display drivers this should clear the problem.
If anyone has working tident drivers for XP SP3 I would be greatfull!!
Aug 04, 2010 | Toshiba Portege 3500 Tablet PC
How to fix a screen on the nokia
Do you Need to avoid Screen Changing/Rotating.....????
  • Go to Settings Menu
There you will find ROTATE SCREEN .then OFF it.....
YOU are done....
Is this Helped you....
You may Feel free Contact me...
Mar 28, 2010 | Nokia N95 Cellular Phone
I want to rotate the screen on my HTC touch VIVA, is there any software or any settings i can change, if software where do i find it
My Hermes allows me to rotate the screen using a hardware button assignment or using the HTC Home plugin. Using a 'touchflo'-like application -with no hardware button to spare- it was annoying going back to my today-screen to rotate the screen.
It turned out the Compact Framework 2.0 has this nice class which would do the trick: Microsoft.WindowsCE.Forms.SystemSettings.ScreenOri entation
So I "wrote" exactly 10 lines of code (including class/function def) to rotate my screen.
Anyone interested: download and install the cab.
+ Does not remain in memory: rotates the screen and exits
+ Now you can create a shortcut to rotate the screen
+ tested on a Hermes (TyTN)
- Requires Compact Framework 2.0 (should be default for Windows Mobile 6.0)
- CF is a huge overhead when only needed for this program, but I'm to lazy to go for the API call (ChangeDisplaySettingsEx)
- No settings: rotates 90 degrees counter clockwise (or 90 degrees clockwise with the Rotate Screen CW cab) -on my TyTN it matches the screen setting when the keyboard slides out-
- Not tested on other hardware, but I expect the worst thing that could happen is a frozen device which will work nicely after a soft-reset. My expectation is based on the fact it's a CF 'call' and not an API call, therefore it does not write to memory locations directly.
Use 'as is'.
I might be tempted to add 'settings' if people actually would use the program and have requests...
When installed on other devices: a message would be appreciated (even if is doesn't work)
Mar 10, 2010 | HTC Touch Viva Cell Phone
Screen won't rotate on my lg xenon when it slides
i had the same problem...this is what you do. u check to see if you have a magnetic phone case or if ur phone has been exposed to any magnets. idk why but magnets mess up the screen rotation. all u have to do is take a magnet and pass over the phone once and it should go back to normal. but dont ever expose the phone to any magnets.
hope this helps
Dec 20, 2009 | LG Xenon GR500 Cell Phone
Screen won't rotate horizontally
run a magnet over the back of the touch screen. hope that helps
Jun 29, 2009 | LG Xenon GR500 Cell Phone
Photo- samsung m500
Hi the Best thing you do is go to the nearest phone repair it maybe your phone robin wire connection inside your phone is full of flux and contaminants so that it trigger the connections that maybe grounded
Mar 16, 2008 | Samsung SPH-M500 Cellular Phone
RIM BlackBerry Storm 9530 Smartphone Logo
254 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
