Question about AT&T Blackberry Curve 8300 Smartphone
The rim of the mouse fell off
The phone fall off the chair and the rim that holds the mouse in place broke and it does not go back in it's place
    Sergeant:
  • 322 Answers
Try opening it and try placing it back.
Posted on Jul 02, 2009
On my Kitchenaid Artisan mixer the 3" silver rod fell out the back. How do I slide back in?
I an sorry but the only Rod in the back of a K45SS is the pivot hinge pin that holds the motor head onto the base. if it fell out then the answer is simple. Turn the mixer upside down and wiggle the base while sliding the pin back in. Once the pin is back in place, there is a set screw in the middle of the shaft that you can see while you are replacing the pin, turn this back down with a flat head screwdriver untill it is firmly against the hinge pin. The culprit of the problem is this set screw. It came loose and allowed your hinge pin to vibrate out and then fall down or fall out as you said. once the set screw is back in place you will be fine. To avoid this problem in the future you might remove the screw entirely and put a drop of "Lock-Tight" on it that will help hold the setscrew in place for a very long time.
Dec 11, 2012 | KitchenAid K45SS Classic Stand Mixer
I fell and hit my shin hard it hurts realy bad what do i do
Well get fitted carpets next that wilkl break your next fall ,as for the shin ?' put a ice pack on it and dont walk on it for a day or so and make hubby do the housework
Dec 11, 2011 | Code Writer Wall Smilies
My cordless mouse fell on my tile floor, about 3 ft. It won't work now. I replaced batteries and pressed reset button on bottom. Anything else I can try?
short of taking it apart to see if something broke, probably not. the concussive force of the fall probably cracked something or jarred something loose
Jan 13, 2011 | Logitech Cordless Mouse
The front tire fell off the rim on my new cub cadet
Did it fall into the rim or out of the rim? If it is out, you have to stretch it back on, get some dish soap on there to help, if you have a couple clamps, use them, I screw the wheels down to the bench with a big screw to hold it, If the tire is in and you can't get the beads to stay put, tie a belt, rope, something on there to hold the beads in place and then fill it up with air. You can do all this with it on the mower, jack it up. I have a feeling it was low on air is why it came off. Keep them pumped up. Hope this helps.
May 07, 2010 | Cub Cadet Street Sign- tractor lawn riding...
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Wheel broke of my Power Chair
I assume you are referring to the caster tire, not the drive tire. You will need to check to see if the rim is a split-rim or a solid rim. A split-rim will have 4 or more bolts holding the two halves of the rim together. If you have flat-free tires i.e., foam-filled solid tires, evidenced by the lack of a valve stem which is used to inflate non-flat-free tires (pneumatic), you would remove the wheel from the caster by rermoving the center bolt acting as the axle. Then remove the bolts holding the rims together. Reposition tire on top of one of the rim halves, then place the other rim half on top so that the bolt holes in the top one line up with the holes in the bottom one. You need to buy a couple of bolts that are about 3/4 in or more longer than the bolts that you removed, as you now must press the two halves back together and the stock bolts probably won't reach through. Put the two longer bolts in opposite of each other in two holes and tighten down. When the rims are pressed together, then put the stock bolts in, remove the two longer ones and replace with stock bolts. Place wheel back on the caster. If you have pneumatic tires (requiring air), make sure to always deflate the tire completely before attempting to loosen the bolts holding the rim-halves together. The same process is used for drive tire replacement. If the rims are not split rims, then it is easiest to buy an entire new wheel and tire as getting it back on is quite a chore requiring a press and lots of tequila! It's easy to break the rims. Good luck.
Jul 15, 2009 | Invacare Pronto M51 Power Wheelchair
New Slider Does Not Work - key lock too!
I Would send the phone back, you could be damaging it even more.
Sep 21, 2008 | Samsung SGH-D600 Cellular Phone
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
AT&T Blackberry Curve 8300 Smartphone Logo
44 people viewed this question
Top AT&T Computers & Internet Experts
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
