Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Ac unit shuts down
What does error check p8 mean
    New Friend:
  • 40 Answers
P8 : diagnosis of malfunction outdoor unit malfunction inspected unit outdoor.
Air Conditioning Fault Codes
Posted on Mar 12, 2014
    New Friend:
    Problem Solver:
  • 9 Answers
Ac unit shuts down
Posted on Apr 16, 2013
    Novelist:
  • 194 Answers
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Posted on Jul 02, 2009
SHUTTING DOWN
Fixing unit protection circuit trouble
0101 When there is a short-circuit detection error in the halogen heater (ASIC detection)
Check the connection of the J114 jack of the AC driver PCB, and replace the AC driver PCB (triac short).
Replace the Pressure heater.
Replace the Fixing unit.
Replace the DC controller PCB 2 (MAISY).
Apr 15, 2014 | Canon irc5185i
Error p8 is coming in the remot unit on after 3 mintus
error p8 is coming in the remot unit after 3 mintus
Dec 26, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
CAN YOU TELL ME WHAT THIS ERROR CODE MEANS P8
P8- Abnormal temp of out door. If new unit, check gas pressure, may be over charged. Release some gas. If existing a/c, check condenser coil- dusty- clean it. Check f.motor- less rpm-replace capacitor. F.motor mechanism locked- replace motor. If above all o.k., non-condensate gas inside. Release all gas, flush out, replace filter drier and vacuum. And do gas charging. Thanks, helpful.
Jan 31, 2011 | Carrier 38CKC018 Air Conditioner
I have a 24 ton mini split, that has never worked correct. It used to blow cold air, but only for a little while, then it set error codes including p4, and p8. The heat functioned used to work ok. Now it...
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor. Due to non condensable gas/over charged/condenser dust blocked.
For non condensable gas, remove gas and flush out and then recharge gas./remove over charged gas/clean condenser coil
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Mitsubishi mr. slim showing P8 on thermostat
p8 means problem at out door unit google mr. slim p8 fult code describes in more detail
Jan 15, 2010 | Humidifiers
Amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jun 30, 2009 | AmcorAire UCHW-H24AF2 Split System Air...
P8 error code on cannon mp260 cannot get to print
The 8 error code just means that the ink absorber is full and needs to be replaced. Power cycling will not help this problem. You need to replace the absorber and reset the counter
http://erkinson.altervista.org/stampanti-canon-codice-errore-lampeggi-led/
Jun 10, 2009 | Canon Office Equipment & Supplies
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
1,633 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
