Question about Canon PIXMA MP150 All-In-One InkJet Printer
E16 My printer display is showing error code E16. I was having a paper feed error and so I followed the instructions on this site. I took the ink cartridges out and turned the printer upside down and shook it. When I put the cartridges back in I am now getting E16. Please help me I need to print off my airline tickets asap. Thanks Alicia
  • F Lada Apr 01, 2008
    I have a E16 error on Pixma MP150, and my color cartridge is empty or dryed.
    My black cartridge is full and print well. Can I skip this E16 and use my full black cartridge without change my color cartridge?
Press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Posted on Aug 30, 2008
  • 42 Answers
Error is: E16 -E19 Failed to scan head alignment sheet
Considered an operator error and not a system error.
Failed to scan head alignment sheet – there is an (Error) at scanning a (sheet) of alignment of heads.
While not 100% helpful, the ability to get this information in more detail requires me to be able to read another language. ;)
Posted on Nov 09, 2007
If you search what's that mean E16 at printer Canon MP Series, the error E16 code is Failed to scan head alignment sheet. I will tell you how to fix the E16, see at below : - If you see at Printer Status monitor while you printing, you will get the dialog it says your ink is running low. - So what you need to do? Press the START button, then until 2-3 second press START button again. I hope that will resolve your problem about error E16. Kode E16 pada printer Canon seri MP, berarti "Failed to scan head alignment sheet". Saya akan mencoba memberitahu anda bagaimana memperbaiki E16 ini. * Perhatikan Status Monitor pada printer anda, akan muncul pernyataan bahwa tinta akan habis (Ink is running low) * Yang harus anda lakukan adalah tekan tombol START, kemudian tunggu 2-3 detik kemudian tekan lagi tombol START.If you search what's that mean E16 at printer Canon MP Series, the error E16 code is Failed to scan head alignment sheet. I will tell you how to fix the E16, see at below : - If you see at Printer Status monitor while you printing, you will get the dialog it says your ink is running low. - So what you need to do? Press the START button, then until 2-3 second press START button again. I hope that will resolve your problem about error E16. Kode E16 pada printer Canon seri MP, berarti "Failed to scan head alignment sheet". Saya akan mencoba memberitahu anda bagaimana memperbaiki E16 ini. * Perhatikan Status Monitor pada printer anda, akan muncul pernyataan bahwa tinta akan habis (Ink is running low) * Yang harus anda lakukan adalah tekan tombol START, kemudian tunggu 2-3 detik kemudian tekan lagi tombol START.If you search what's that mean E16 at printer Canon MP Series, the error E16 code is Failed to scan head alignment sheet. I will tell you how to fix the E16, see at below : - If you see at Printer Status monitor while you printing, you will get the dialog it says your ink is running low. - So what you need to do? Press the START button, then until 2-3 second press START button again. I hope that will resolve your problem about error E16. Kode E16 pada printer Canon seri MP, berarti "Failed to scan head alignment sheet". Saya akan mencoba memberitahu anda bagaimana memperbaiki E16 ini. * Perhatikan Status Monitor pada printer anda, akan muncul pernyataan bahwa tinta akan habis (Ink is running low) * Yang harus anda lakukan adalah tekan tombol START, kemudian tunggu 2-3 detik kemudian tekan lagi tombol START.If you search what's that mean E16 at printer Canon MP Series, the error E16 code is Failed to scan head alignment sheet. I will tell you how to fix the E16, see at below : - If you see at Printer Status monitor while you printing, you will get the dialog it says your ink is running low. - So what you need to do? Press the START button, then until 2-3 second press START button again. I hope that will resolve your problem about error E16. Kode E16 pada printer Canon seri MP, berarti "Failed to scan head alignment sheet". Saya akan mencoba memberitahu anda bagaimana memperbaiki E16 ini. * Perhatikan Status Monitor pada printer anda, akan muncul pernyataan bahwa tinta akan habis (Ink is running low) * Yang harus anda lakukan adalah tekan tombol START, kemudian tunggu 2-3 detik kemudian tekan lagi tombol START.If you search what's that mean E16 at printer Canon MP Series, the error E16 code is Failed to scan head alignment sheet. I will tell you how to fix the E16, see at below : - If you see at Printer Status monitor while you printing, you will get the dialog it says your ink is running low. - So what you need to do? Press the START button, then until 2-3 second press START button again. I hope that will resolve your problem about error E16. Kode E16 pada printer Canon seri MP, berarti "Failed to scan head alignment sheet". Saya akan mencoba memberitahu anda bagaimana memperbaiki E16 ini. * Perhatikan Status Monitor pada printer anda, akan muncul pernyataan bahwa tinta akan habis (Ink is running low) * Yang harus anda lakukan adalah tekan tombol START, kemudian tunggu 2-3 detik kemudian tekan lagi tombol START.If you search what's that mean E16 at printer Canon MP Series, the error E16 code is Failed to scan head alignment sheet. I will tell you how to fix the E16, see at below : - If you see at Printer Status monitor while you printing, you will get the dialog it says your ink is running low. - So what you need to do? Press the START button, then until 2-3 second press START button again. I hope that will resolve your problem about error E16. Kode E16 pada printer Canon seri MP, berarti "Failed to scan head alignment sheet". Saya akan mencoba memberitahu anda bagaimana memperbaiki E16 ini. * Perhatikan Status Monitor pada printer anda, akan muncul pernyataan bahwa tinta akan habis (Ink is running low) * Yang harus anda lakukan adalah tekan tombol START, kemudian tunggu 2-3 detik kemudian tekan lagi tombol START.If you search what's that mean E16 at printer Canon MP Series, the error E16 code is Failed to scan head alignment sheet. I will tell you how to fix the E16, see at below : - If you see at Printer Status monitor while you printing, you will get the dialog it says your ink is running low. - So what you need to do? Press the START button, then until 2-3 second press START button again. I hope that will resolve your problem about error E16. Kode E16 pada printer Canon seri MP, berarti "Failed to scan head alignment sheet". Saya akan mencoba memberitahu anda bagaimana memperbaiki E16 ini. * Perhatikan Status Monitor pada printer anda, akan muncul pernyataan bahwa tinta akan habis (Ink is running low) * Yang harus anda lakukan adalah tekan tombol START, kemudian tunggu 2-3 detik kemudian tekan lagi tombol START.
Posted on Oct 25, 2012
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Tip
Code error PIXMA MP160 All-In-One InkJet Printer
this error list PIXMA MP160 /150 All-In-One InkJet Printer
CANNON PrintersMP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported inkcartridge is installed ,
or the ink cartridges are notinstalled properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera /video camera does not support Camera
DirectPrinting
E14 The Ink cartridges whosedestination are wrong
E15 Ink cartridge is notinstalled E16 - Ink remaining is unknown
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature riseerror
E27 Waste ink absorberfull or platen waste ink absorber full
E28 Ink cartridge temperaturerise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
on Mar 15, 2008 | Canon PIXMA MP160 All-In-One InkJet...
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error – USB
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
What does E2 mean??
Error code
E3-3 = Paper jam
E4 = No ink
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E22 Carriage error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
visit manufacture website for more user manual guide..
Jul 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Error code e22 flashing on display ever since we put in new ink from tesco
CANNON Printers ERROR CODE
Direct Printing
E22 Carriage error
E29 EEPROM error
might have to reset the waste ink this way :
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Feb 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP150
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer:
CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing
E22 Carriage error
E29 EEPROM error
turn the printer off and lift  the front top and move the cartridge carriage manually at the center and then on the printer.
Mar 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have problem error code e23 for my canon printer pixma mp150 what can i do for solve this problem pls help me tq
Hi raj2006678,
The code e23 indicates a paper feed error. Check to be sure that your paper is loaded correctly and that the rollers are functioning properly.
Here is the complete list of error codes for the MP150:
E2 No paper (ASF)
E3 Paper jam
E4 No ink
E5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E16 Ink remaining is unknown
E22 Carriage error
E29 EEPROM error
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printer will not work. Error E3
What may have happened is that the Paper sensor is locked down and tells the printer that there is paper in the path (although there isn't any). The paper sensor is a toggle switch and there is a paddle that pushes it down as the paper goes in/out. Look on the right side of the unit ,under the roller assembly. Sorry, but I do not have a service manual for this unit.
Error list :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp 160
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
cropp
Jan 14, 2008 | Canon PIXMA MP160 All-In-One Printer
PIXMA MP150 => it says E-2-3... Please HELP!!
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer: CANNON Printers MP150/MP160 ERROR CODE E9 The connected digital camera / video camera does not support Camera Direct Printing E14 The Ink cartridges whose destination are wrong E15 Ink cartridge is not installed E16 - Ink remaining is unknown E16 -E19 Failed to scan head alignment sheet E22 Carriage error E23 Paper feed error E24 Purge unit error E25 ASF(cam) sensor error E26 Internal temperature rise error E27 Waste ink absorber full or platen waste ink absorber full E28 Ink cartridge temperature rise error - E29 EEPROM error E33 Paper feed position error E35 15 USB Host VBUD overcurrent error - USB E37 17 Abnormal motor driver error E40 20 Other hardware error E42 22 Scanner error
Oct 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
5,680 people viewed this question
old marine
old marine
