Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
I am getting an error code that says "AGS" on the display of my Laars 400 LX. The fan starts up when I switch the heater on, but the furnace does not ignite. The gas valve is definitely on to supply gas. Any ideas?
  • barry175 Jul 02, 2009
    The filter is absolutely clean. I had the gas valve shut off for about 2 years to ensure that the pool man did not make the mistake of leaving the heather on during the winter (which he did once and which cost me $1,000 in natural gas). The fan comes on and so does the blower which indicates that mechanically things are working. The LED display even shows "heat" for about 15 seconds before the unit shuts off, presumably because it is not getting ignition. Does that help you further in diagnosing the "AGS" message?
    President:
  • 942 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi...
AGS is automatic gas shutdown,
can be caused by problems with pump pressure, or low gas supply pressure
Check the pump pressure if it is ok, if it is ok, check also the gas supply pressure
Regards
PCmania
Posted on Jul 03, 2009
    Genius:
  • 1,847 Answers
AGS is automatic gas shutdown, can be caused by problems with pump pressure, or low gas supply pressure and circulation problem or flame rectification. Is the filter clean and circulating at a good flow.
Check this link for details.
http://forum.doityourself.com/archive/index.php/t-325210.html
Thanks
Kinldy rate the answer
Kevin
Posted on Jul 02, 2009
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
Lx 400 pool heater with ags error code
check pressure switch and copper tube
Jun 15, 2012 | Jandy Pool & Spa
Jandy 400 lx ags
check gas pressure if ok check safety circuit
Feb 26, 2012 | Jandy Laars Lt 400,000 Btu Heater
My Laars LX pool heater would shut off soon after it fires up
This error is Automatic Gas Shutdown. Here is what you can do:
  1. Check for fluctuating pump pressure (air in strainer, pressure guage bounce)
  2. Check all wiring connections
  3. Replace ignitor/flame sensor assembly
Depending on your expertise, it could also be the gas valve or ignition control (aka the IID).
Since the burners do fire briefly, I would suspect the flame sense rod first. Attached is a link to the owners manual in PDF.
Lo Nox heaters can be a little tough so follow the directions exactly.
Jul 24, 2010 | Teledyne Laars Laars Lx Pool Heater /...
What does service ags mean on a LAARS LX pool heater?
AGS stands for Automatic Gas Shutoff. This means the heater failed to sense a flame or flame rectification. When this occurs, the the gas valve will close as a safety precaution. The heater will have to be reset to get another call for heat.
May 18, 2010 | Jandy 131K BTU LAARS AIR ENERGY HEAT PUMP...
Laars lx 250 fault code "AGS"
make sure safety circuit is ok that cuts off fan and check pressure switch and hi limits
May 22, 2009 | Jandy LAARS LX250 - PROPANE, DIGITAL...
Code AGS, heater wont light
replace temp sensor for aqualink mounted in plumbing from pump
Mar 15, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
325 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
