To connect your Canon ZR 800 camcorder to your MacBook Pro using a Firewire connection, you will need a Firewire cable and a Firewire port on your computer. Here are the steps you can follow to connect your camcorder to your MacBook Pro:
Locate the Firewire port on your MacBook Pro. It is usually located on the side or back of the computer and is marked with a symbol that looks like a small lightning bolt.
Connect one end of the Firewire cable to the Firewire port on your MacBook Pro.
Locate the Firewire port on your Canon ZR 800 camcorder. It is usually located on the side or back of the camcorder and is marked with a symbol that looks like a small lightning bolt.
Connect the other end of the Firewire cable to the Firewire port on your camcorder.
Turn on your camcorder and set it to playback mode.
Open the video editing software on your MacBook Pro and choose the option to import video from a Firewire device.
Follow the prompts in the software to import the video from your camcorder.
I hope this helps! If you have any further questions, don't hesitate to ask.
The functioning of your Mac Book is a little different from Windows. It is possible that this may get you confused. Let's take a look at the steps for Canon Pixma MG2522 setup in Mac. Click on 'Drivers and software' options in your printer and chose the version of Mac OS you are currently using. Start downloading the printer driver on Mac. Then, double click the downloaded file to run it. Now, you have to select the 'Continue' button twice. Thereafter, press 'Install' to add the Canon Printer to your Mac Book.
Please check the internet settings of the Lan connection in the Mac Book. May be there is IP Address or DNS settings is installed in your Mac Book which are stopping the wireless network services. Please check the IPV4 settings in the Lan or wireless connection properties.
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally.
-Ken
Check your router's IP address from the Compaq machine. Get a command prompt and type ipconfig .all Then wright down the IP settings. Check the IP settings of the Macbook Pro. Adjust settings. You can give a Static IP also. If needed. But you have to set the default gateway -Enter previouse IP settings for those. Check ur Wi-Fi settings also. :) If this is helpful to u please rate Thanks Wish U Luck
You should check to see if you have the connection set to static or to scan. Your computer could be set to scan, and so when it recieves a stronger signal, even if it is for a second, it will disconnect from the signal you have current. You can go to system preferences , select NETWORK, go to show, then AIRPORT, make sure your signal of choice is at the top of the list.
Hi, i also have a conia plasma (and sony 510 amp). Which video connection are you using? DVI-VGA? DVI-component? Note that the tv probably defaults to using YPBR rather than VGA so you may need to play with settings in the menu ...
