Question about Sylvania Televison & Video
Recording Error 03-56
I have a Sylvania HDRV200F that worked fine for over a year. Now I get Recording Error 03-56 when I try to dub from the HDD to DVD. I called Sylvania Customer Service, but they don't have any sort of error message decoder (why give the errors numbers if no one knows what the numbers mean?). They suggested unplugging the device for 45 minutes to an hour (which did not work) or using a disc cleaner (which I haven't tried yet).
I have a feeling the DVD recorder portion of the device is dead.
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Posted on Jul 01, 2007
SOURCE: EWR20V5 DVD Recording Error
I live in Ft. Worth, Tx and I have the exact problem. My unit plays both dvd and vhs, but won't record. I get the same error code E4 54037380. I paid over 200 dollars in Jan. 2006 for this unit. After reading your comments, I'm not going to waste my time with their customer service. I wasted alot of dics thinking the dics I bought were bad. Lesson learned, DON'T BUY EMERSON PRODUCTS!!!
Posted on Sep 08, 2007
SOURCE: Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
Posted on Jun 24, 2008
  • 4 Answers
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Posted on Jul 19, 2008
SOURCE: unable to "dub" my 8mm tapes onto DVD-R using my Sylvania DV90VE
From comments posted on the Internet by other Sylvania users with a similar problem, I  learned that I had to use a 4X DVD-R (the ones I had been trying to record on were 16X). And I found that Office Depot sells the sometimes hard-to-find 4X format, so that's where I'm headed right after lunch.  Thanks.
Posted on Dec 15, 2008
Need manual for sylvania model HDRV200f sn D49512690A try here. Just came across it somehwere on the FixYa site, buried on an obscure page. Who knew?
Aug 16, 2012 | Funai PY90VG DVD Player/VCR
I have a Magnavox H2160MW9 A. It has a dubbing feature and says I can copy from HDD to DVD. But when I follow the instructions "Selected Title Dubbing", The dubbing selection is grayed out. Note that I'm...
Choose Dub on remote. Choose HDD to DVD. When you are looking at your HDD Titles, move the cursor (the highlighted box, using the left/right buttons on your remote) to the title you want to Dub. Hit the OK button on your remote. Then hit the Dubbing button on your remote. If you are ready to record, move cursor down to Start Dubbing. Choose speed, then hit OK button.
Jun 19, 2010 | Magnavox H2160MW9 HDD Recorder
Hello, when dubbing from DV mini tape to HDD
well one solution may be the speed you are recording at. L.P. recording on a dvd often creates this problem. but usually it is when you copy dvd to dvd, not mini dvd to dvd
Never record more than 2 hrs on a disk
there are programs for a work around that reprocess the dvd vob file with adjustments for the sync.
could also be a hardware problem
is your mini dv long play source as well?
May 18, 2010 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Dubbing from DVD to HDD
When you insert the dvd are you in dvd mode or hdd mode I think you have to be in hdd mode then go to settings insert dvd that you want to dub wait then it should become not greyed out, I had a similar problem when i tried to burn a dvd from hdd I had to be in hdd mode to dub I hope this helps let me know
Jan 23, 2009 | Philips DVDR3575H/37
Unable to "dub" my 8mm tapes onto DVD-R using my Sylvania DV90VE
Dec 13, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Will not dub to dvd-r from HDD in high speed mode
It will only high speed dub in the speed it was recorded in. You can dub, for example, SP on your hard drive to SP on a DVD. You cannot dub high speed, for example, SP on your hard drive to LP on a DVD.
Dec 01, 2008 | Panasonic DMR-EH50 DVD Recorder
HDD>DVD dubbing.....stopping, creating coasters
Still unable to find a solution for this problem. No response from JVC on their product either.
Jun 25, 2008 | JVC SR-DVM600
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
Dubbing from HDD to DVD
If the record mode of the original hdd recording was set for 2hr or 3hr mode, you will not be able to fit any more on the disc.
Dec 21, 2007 | Philips DVDR3575H/37
Copying from hdd to dvd
1. select the recording you want to copy.
2. press the SELECT button. You should see a yellow / red icon by the title.
3. press RECORD / DUB.
Oct 04, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
112 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
