Kenmore washer wont drain or spin
Model 110 20422 990 Got advice last night that it might be the lid switch. My Question is, before I remove and replace it is there a way to bypass the lid switch to ensure that is the problem?
    President:
  • 1,136 Answers
Hi, Remove the end caps on the control panel. There is 2 screws in the front corners that need to be removed and the control panel will lift up. Locate the lid switch connection disconnect it. Use an insolated wire and jump the two brown wires and see if the washer will spin. The green wire is groun (Do not use that wire)
I hope this helps you.
Vic
Posted on Jul 02, 2009
  • 315 Answers
I am not taking LID Switch as an issue first try the below steps:
If you opened and closed the door and it started, that sounds like a bad, door switch in the console.
But you did hear a hum sound when it tryed to drain, it could be the drain solenoid, or the motor/pump assembly.
Take off the bottom access and look at the solenoid when it starts to drain, the piston in the solenoid should move freely, up and down with the white drain flapper that it connects to.
Also check for bad wiring connections at the power junction box where the power hooks up to it under the dishwasher, i have seen the wire nuts either come loose or burn off due to loose connections.
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore washer front load 417 wont spin
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
I have a kenmore washer 70 series it wont drain or spin it did work until it got to the drain cycle and then quit
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Nov 07, 2010 | Kenmore 22422 Top Load Washer
I have a kenmore washing machine and it will go to rinse but it wont go to spin cycle and the water wont drain out of the washing machine it wont go through all the cycles just rinse nothing else what do i...
Aug 13, 2010 | Kenmore Washing Machines
Machine agitates but wont drain
May 30, 2010 | Kenmore 22422 Top Load Washer
Wont run cycles. fills up but wont spin or drain
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
If it works, the Lid Switch is a relatively inexpensive part.
Apr 17, 2010 | Kenmore 23822 Top Load Washer
Kenmore model # 110. 24422300. Will not do anything. Full of water, won't drain, spin or re-start in any way.Worked fine last week. Tired it on Thursday still won't drain on Saturday.
Assuming that you cannot hear the motor the problem is likely the lid Switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
washer back in.
Mar 13, 2010 | Kenmore Washing Machines
Spin cycleis out, doesnt even hum....
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Oct 02, 2009 | Kenmore 15864/15862 Top Load Washer
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
311 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
