Question about Pentax Optio E60 Digital Camera
Lens error on new camera. Will not operate after 1 month use. Serial Number 1283712
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
When i turn on camera i get message lens error 25
According to the symptom you have to replace the optical lens assymbly. Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Additionally, here is a video of the normal power up sequence of the camera and there other moethods:
1. Here is the first alternate method
2. Here is the second alternate method
Good luck.
Jun 07, 2011 | Kodak EasyShare CD33 Digital Camera
Where is the serial number on the Leica X1?
On the Leica X1, unlike other Leica M's and digitals where the serial is on the hotshoe, the serial is actually on the front of the lens, alongside the lens label.
Elmarit 1:2.8 is on the right hand side of the lens and on the left is the serial number.
Feb 10, 2011 | Leica X1 Digital Camera
D80 Digital Camera with 18-135mm Lens: I have a Nikon D80 with 18-135 lens. Just had err...
Having gone over a month with no response, I assume this is no longer a problem.
May 16, 2010 | Nikon D80 Digital Camera with 18-135mm...
Where do i find the serial nb
On the bottom of the camera, just below the lens, there's a sticker. The sticker starts with Canon PC1267, the next line reads DC 3.15V, and the line directly below that is the serial number.
Jul 16, 2009 | Canon PowerShot A470 Digital Camera
Canon SD 850 says lens error,
There could be a number of reasons for the lens error. ie. . sand in camera, impact damage etc. Typically the lens can be dissasembled and repaired by a competent camera repair technician. If you are certain that you did not damage the camera in any way I would send it back to canon for a warranty repair. If you however think you could have damaged it you are probably looking at around $100 to repair the camera. Hope this helps!
Jun 09, 2008 | Canon PowerShot SD850 IS Digital Camera
The s/n that i have on my disc wont work when i try to use it in the setup wizard so i can put my pics in my pc
ivitar Entries
May 29, 2008 | Vivitar Cameras
Lens problem
That's a fairly new camera, and is likely still under warranty. Contact Canon first to see if they'll help 1-800-828-4040 or 1-800-OK-CANON (1-800-652-2666).
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or Canon will not help, they're worth a try:
Apr 06, 2008 | Canon PowerShot SX100 IS Digital Camera
Old vivitar lens to adapt to a new digital camera
You don't need the serial number, you need the model number. Look for numbers inscribed on the ring around the lens opening or on the body of the lens somewhere.
Mar 28, 2008 | Cameras
Pentax Optio E60 Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
