Question about Two-Way Radios
  • 1640 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual
Posted on Oct 23, 2008
  • 1640 Answers
SOURCE: motorola walkie talkie t4508
This one should be a very close match. The T4508 is a foreign version of the T4500.
Posted on Jan 07, 2009
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
Posted on Jul 01, 2009
  • 1640 Answers
SOURCE: walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide:
Best regards.
Posted on Feb 06, 2010
  • 1640 Answers
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
You have your interference code eliminator set differently on the two radios. Here is a link to the T5 user guide (sorry I didn't have a link to the T3, but they should be very similar):
Posted on Feb 28, 2010
  • 2777 Answers
SOURCE: have Cobra Micro Talk Walkie Talkies and have lost
This was extremely difficult to find but I have located the manual for you on these walkie talkies. It will be easiest to just use the manual and follow the instructions. If you still have questions or problems please respond here and I will get back to you. Please rate my answer 4 thumbs up here on the site, it is very important to me. I would be forever grateful. Here is the manual:
Posted on Oct 12, 2010
0 characters
1 Points
Audiovox GPRS 2way radio manual?
You can download it from here:
Feb 17, 2015 | Audiovox GMRS-602PK 2-Way Radio Walkie...
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Two-Way Radios
Audiovox GMRS1072CH MANUAL
You can download the manual from here:
Jul 10, 2014 | Audiovox 2-Way 14 channel FRS Family Radio...
How do i make my audiovox walkie talkie stop making a beep noise
In the "settings" there should be an option to turn off "beeps" or "tones" or "notifications", something to that effect.
Feb 16, 2014 | Two-Way Radios
Where can I get the belt clips that go on the back of my Audiovox FR-1438 Walkie Talkies ??
I'm not familiar with that make of radio, but try taking the unit to your local Radioshack or similar store, and I'm sure they will come up with a solution.
I hope this answer helps you find the part.
Feb 04, 2013 | Audiovox Fr-1438 Two Way Walkie Talkies...
There are a select number of preprogrammed channels available in the T5930. The programming cannot be changed by software. Sorry. Here is a link to the manual Programming instructions begin on page 18.
Best regards.
Oct 12, 2010 | Motorola Walkie Talkie 2-Way Radio
Walkie talkie batteries don't last
What you have been using are consumer grade walkie talkies. The rechargeable battery packs in them should last a full business day, unless you are in a high use area. This being said, it is also possible you might need to replace the rechargeable battery pack as they usually have just a one year life expectancy. As they start to fail they will go less and less time in a day.
To answer your question about a radio which will go a full business day, any of the business division Motorola handheld radios would work. Radios such as the CP110, BPR40, CP185, and CP200 are all make to go a full day and sometimes more. Their battery packs depending on chemistry would also need to be replaced every 18-24 months.
Best regards.
May 14, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
I got these walkie talkies audiovox
try to work the ptt switch on and off rapidly a few times see if that works.
Apr 11, 2009 | Audiovox GMRS602PK 6-MILE GMRS 2-WAY RADIO...
Two-Way Radios Logo
157 people viewed this question
Top Two-Way Radios Experts
Are you a Two-Way Radio Expert? Answer questions, earn points and help others
