Question about Kenmore Oasis HE 27082 Top Load Washer
My Model number is 110.27062603 and I am having problems with my washer. I have had to have a repair guy come to my home five times and it is still under warrenty. Should I have them come and pick up and get another or just continue to have the same problem over and over. I have always bought at Sears and never had a problem like I have since I bought this washer and dryer.
  • 53 Answers
Same problem 5 times lemon law
Posted on Jul 09, 2009
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
I would like an exploded view inside the agitator shaft of a kenmore washer, model # 110.7204705.
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer repair manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct BUT it is possible it will supply only to its own engineers.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 11, 2011 | Washing Machines
Electrical scheme for miele washer model WS5514 MS wanted to effect electrical repairs
You could also try the manufacturer's web site direct but some only supply to their engineers ;-0(
John C.
Apr 26, 2011 | Miele Washing Machines
I need manual parts, you have this.
You could also try the manufacturer's web site direct but some will only supply to their own engineers ;-0(
John C.
Apr 24, 2011 | Asko W6021 Front Load Washer
The washer washed after it finished it washed another time and i need manual
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
Good luck,
John C.
Apr 10, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Need a manual for washer model # mah8700aww
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Good luck,
John C.
Mar 25, 2011 | Maytag MAH8700AWM Neptune Front Load...
We have lost our operators manual for the above washer
Sorry-you do not say what make and model! In any case we do not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Good luck,
John C
Mar 08, 2011 | Washing Machines
Have ge model WCVH6800J1MV Will be 1 year old in Nov. it bangs and walks across the floor. it also vibrates and makes loud "clicking" noises have had five service repair visits all to no...
had the same problem but 7 or 8 months it started had it replaced and 7 or 8 months on new again same problem, a speed wash which is 36 mins takes 1.5 to 2 hrs
Oct 27, 2010 | GE WBVH6240F Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
254 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
