Question about LG LP6000ER Air Conditioner
Water coming out of unit. - LG LP6000ER Air Conditioner
  • 400 Answers
Your drain pipe is blocked. You can **** on the outlet pipe on the outside of the building to clear it. Unless you have a water vacuum machine which you could also use
Posted on Jul 02, 2009
Water puring out underneath Gaggenau coffee machine
The water in unit is fed via a hose to the heating element. If the hose is broken or disconnected the water never reaches the element and spills out the bottom nice and cold.
If you remove the bottom panel the problem will be instantly obvious.
OR put water in unit and see where it comes out of!!!!!!!!!
Aug 30, 2015 | Gaggenau CM 200-630 Aluminum Espresso...
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Keurig b40
We need to determine where the leak is...
Unplug it...
Start by removing the water resevoir...dry out what you can with paper towel...
flip it over on a table with a bath towel. Take off the metal bottom plate
you can then check for water inside the unit.
since you didnt say where the water is coming from... the K-Cup arm or the bottom...
I will assume the bottom is where the water is coming from.
Hoses on these units are fastened with 4 inch "Ty-Wrap" nylon fasteners.
You may have a broken one, and need to replace one... hopefully it is located on the bottom between the water fill and the main water motor... which you shouold be able to see when the bottom metal pan is removed...
If the water is coming out from the top. then I suspect hot water expansion is bypassing one of the valves, or there is a nylon strap/hose combination you cannot see instde the unit...
Hopefully it';s the bottom
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 17, 2010 | Keurig Elite B40 Coffee Maker
My bosch dishwasher check water light has come on and the water has stopped circulating round
check your fill hose. thats the water coming into unit . if its not that then your water valve is bad. unit is not receiving water. if this helps you please send me a 4 thumbs uo post
Feb 22, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My g595sc miele dishwasher after about 2-3 minutes of working come to stop with the "WATER INLET" light on. Please help.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Jan 22, 2010 | Dishwashers
Water won't come out and the ice maker doesn't fill to make ice. the lines to the fridge have water that comes out but somewhere the water is not getting through
the water command come from the ice maker unit if the comand to the volve 120v for short time dont get to the volve then the ice maker unit is bad and need to be replace.
Dec 29, 2009 | Kenmore Refrigerators
My whirlpool dishwasher cleans well but once the rinse cycle is completed and drained the next day the washer has water in it. HELP!
it could be a bad fill valve.to chk this ,open the door and look for the inlet hole from where water comes in.if u see and droplets of water coming down the hole then it is the fill valve.when machine is off the fill should be closed and no water should come in.
other thing could be ,if u have hooked up the drain pipe of the unit directly to the food disposar instead of going through air gap mounted at the sink then some water from the disposar could flow back into the unit.units have chk valve valve built in drain pipe but some times they work 100%.also chk 2 c if water insinde unit is dirty or fresh to confirm above things.
Aug 22, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
Estro magic delux (now saeco i think) water leaks below brew unit
There is a small metal plate with holes below the square funnel shape on the brew unit. This plate has a pink rubber seal and a stem that goes up into the brew unit. The stem is knurled with ridges and is attached to a screw on the plate. The screw has become loose and the plate is not held tight against the seal. Turn the knurled knob clockwise until it tightes the plate against the bottom of the unit. Make sure the plate is centered as I believe there is a slight lip that it recesses into. Should stop the water in the grounds collector. Of course the seal must be in good condition. Paul
Feb 02, 2009 | Saeco Magic De Luxe Espresso Machine
No water
That water is condensate that is removed from the air. If the humidity is low, you will notice much less water coming from the condensate drain line. I would expect to see some water though.
If the unit doesn't seem to cool as well as it did, then chances are it has a leak and has lost its refrigerant charge.
Sep 18, 2008 | Kenmore 75050 Wall/Window Air Conditioner
LG LP6000ER Air Conditioner Logo
123 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
