Question about Epson Stylus Photo R1900 InkJet Printer
Can't select Velvet Fine Art Paper from Media Type dialog box
I have downloaded and installed all of the appropriate ICC Profiles. I did this twice to make sure that the first profiles were not corrupted. I have emailed epson about this but they are dragging their feet getting back to me.
I have the same problem! I have Photoshop CS and an imac but I have to go back to my elements program which is on my PC, plug my printer into that--and THEN click "velvet fine art paper" through IT. I don't think the option exists at all with my other set up. Thankfully I have two set ups! You didn't say what program you were running. I think that's it. Maybe get a used Elements program from Amazon and install it to use for printing with whatever other software you are using.
Posted on Jul 25, 2009
HP officejet pro 7680 print settings for iron on transfers
as a paper profile when loading use a paper that is nearest to the paper type being printed- EG- plastic sheets would become Vinyl paper/ transparency or banner profile.#
alternatively go to HP website and then to paper profiles and download the ICC profiles required follow the user manual to install to printer.
Jan 17, 2014 | HP OfficeJet Office Equipment & Supplies
There are black ink smudges on the bottom corners and edges of my color prints on velvet fine art paper. How can I stop that from happening. I already cleaned the heads twice. The prints are great...
The R2400 has an option to load paper on-top (Epson calls it the Automatic Document Feeder) and at the back. Based on the printer's User Guide the Velvet Fineart Paper should be loaded at the back. (Epson called is the Manual Single Sheet Feed).
Look at the User's Guide availabe on their website.
Jan 19, 2010 | Epson Stylus Photo R1800 InkJet Printer
My color photos print darker then they appear on my monitor. I use Huey pro to callibrate, I use photoshop and print to an Epson 3880, using the Epson supplied profiles. I turn off printer management and...
You need to select the correct Printer Profile for the type of paper you are using. If you are using non-Epson paper, you need to download the ICC Profile from the paper mfg. website.
You also need to check if the paper is comparable to an Epson paper that the printer supports. If the paper your using is not comparable to any Epson paper the printer supports then you might want to try using another kind of paper. Epson prefers Epson Paper. You can also try any non-Epson paper as long as it is comparable to any Epson paper the printer supports. Try to go to their website and look at the printer's specifications. It lists all type of paper the printer supports.
Jan 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
How do I print with diffrent paper sizes?
  1. Press the Cancel button on the product to stop the current print job, if necessary.
  2. In the software program that you are using to print, click File , and then click Print .
  3. Make sure that the appropriate product is selected.
  4. Depending on the program, click Properties , Options , Printer Setup , or Printer . The Print Properties dialog box opens.
  5. Click the Features or Print/Quality tab.
  6. In the Paper Type or Type Is drop-down list, click the appropriate paper type.
  7. In the Size or Size Is drop-down list, Click OK to save the settings.
  8. In the Print dialog box, click Print or OK to start printing.
Nov 28, 2009 | HP J3680 Officejet All In One Printer
Can't select Velvet Fine Art media type when using sheet feeder as source.
I had the same problem, same printer. So with a little checking I found a solution. The paper has to be fed through the single page paper feeder. (See manual to setup. Can be downloaded from Epson.) Select manual/roll in the page setup section when you're ready to print. For instance, I was using 8.5 X 11 velvet, so select letter > then subset of roll/manual. After doing this velvet and other specialty paper profiles were selectable.
May 28, 2009 | Epson Stylus Photo R1900 InkJet Printer
When printing to an Epson R1800 have a problem
Make sure the paper size is not set to US letter sheetfeeder borderless use just US letter. the borderless function slightly enlarges document content to ensure that it bleeds overthe edge. If your has a bleed, use in page setup - US letter sheetfeeder borderless - In the print dialog box click printer button which brings up a warning about using a different settings dialog box, - continue on to the r1800 print dialog box. about midway down is a pull down menu - choose expansion and adjust it to the lowest setting. if your printout does not bleed to the edge bump the expansion adjustment up 1 measure.
Apr 11, 2009 | Epson Stylus Photo R1800 InkJet Printer
Could not read the ICC profile. Saving image canceled.
ICC = International Color Consortium.
The ICC's should be installed in the default printer directory.
Also, you may want to check the printer profile. In printer properties under the "color management" tab check to see if automatic or manual is highlighted. If manual is highlighted, be sure the print profile matches that of the paper you are using. You can select any of the included profiles as the default or add your own from a third source. Such third-source profiles are most often specified by your software provider
Mar 24, 2009 | Epson RX595 Photo All-In-One Printer
PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus Photo R1900 InkJet Printer Logo
521 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
