Question about HP LaserJet 4100n Printer
Printer Pauses every few pages, seems to print slower than it shouls
We have a HP LaserJet 4100tn and an HP LaserJet 4100n. The 4100n seems to print significantly slower as it it pauses for a few moments every few pages. When it pauses, it sounds like it is winding down then firing back up again. Is this just a low memory issue?
  • joeyoung25 Jun 23, 2008
    I am also having the same problem and have tried many different settings on the driver side but none of them make any difference. for more details: the users are printing about 30-page jobs, the first page is from tray 2 and second is in tray 4 and then back and forth between the two trays.
  • 3 Answers
I seriously doubt that this is a network spooler issue but I guess there is a possibility. I was thinking that there is a setting with the paper on the actual printer or something about waiting to start the job until all pages are in memory. I have the problem with a 4300 not a 4100
Posted on Jun 23, 2008
  • HP Master
  • 1,113 Answers
More likely to be Network print spooler issue, check settings on driver.
Posted on Dec 18, 2007
How do I connect my HP Laserjet 4100 to my router?
HP LaserJet 4100 printer C8049A HP LaserJet 4100n network-ready printer C8050A HP LaserJet 4100tn network-ready additional tray printer C8051A HP LaserJet 4100dtn network-ready duplex printer C8052A
Which model do you have? There is an optional card to install before you can have it connected to an Ethernet network if you just have the 4100 model.
Oct 29, 2010 | Computers & Internet
Hello, I can't seem to get my hp Laserjet 4100tn to print. I have set it as the default printer but when I hit print nothing happens. It just sits in the printer file reading error. Any ideas on what...
If this is a recent problem that just popped up I would clear out the print que on your computer where it says "failed to print"
Turn off the printer for a few seconds then turn it back on. Wait 1 minute then try printing again. If this does not resolve the problem then do the same again but also reboot your PC. 9 times out of 10 when a printer suddenly stops printing, rebooting the printer, the PC or both will fix the problem.
If none of this works then you could have a bad network card in the 4100.
Good Luck and Thank You for using Fixya.
Oct 12, 2010 | HP LaserJet 4100 Printer
My HP 4100TN laserjet printer keeps going offline, in the middle of my printing. i switch it on and off and then it will resume. can you help please
first try a cold reset... power off machine hold down green button when power back on..if problem persists..replace with internal jetdirect card..
Dec 29, 2009 | HP LaserJet 4100tn Printer
I want to print from my HP Laserjet 4100N tray 2 instead of tray 1. How can I do that?
Do a Configuration Page print out from the printers 'Information Menu'
Perform a paper path test from tray 2;
<Information Menu> , <Item> , <paper path test> , <Select> , use <Value> to select <Input Tray =2> , <Select> x 3 times.
Is the print out correct?
Check the paper size setting for Tray 2 matches the size you are trying to print onto.
Check / Adjust setting in the 'Paper Handling' menu.
Make sure Tray 1 has no paper in it when you send the print Job.
Check your Driver settings in Windows
Dec 22, 2009 | HP LaserJet 4100n Printer
LaserJet 5Si printing slow use to be able to hit the print key then the printer would fire away. seems like the printer pauses between pages then prints maybe 3 to 4 pages per minute
Could be software. I have seen the last several Adobe latest version documents take several seconds to print. I have also seen increased print times with MS office 2003 Powerpoint documents.If it is a single page MS Word or Excel document and u are printing several copies of it, you should turn off the collate feature for printing of that document
Dec 05, 2009 | HP LaserJet 5si Printer
The right side of the printable portion of each doc prints light
You just need to remove the toner and reach in with a dry rag and wipe the little inch wide window that is above where the toner goes. This window gets covered with toner dust and makes prints lighter...It runs all the way from right to left above the toner and drum.
Nov 03, 2009 | HP LaserJet 4100tn Printer
Paper printing with wrinkles on hp 4100 laser
Pressure roller is worn. But the whole fuser assembly could probably stand to be replaced.
Mar 28, 2009 | HP LaserJet 4100n Printer
Can't install hp laserjet 4100tn with no cd how do i install
Go to hp web sight and download the setup software. fast easy
Jan 14, 2009 | HP LaserJet 4100n Printer
4100 stops printing mid streem and engins continue to run
Try printing out an error log and seeing if that leads you anywhere.
Nov 25, 2008 | HP LaserJet 4100tn Printer
Laser Printer Cleaning
Does the dirty background get lighter as you print additional pages? Have you tried a new cartridge yet? Unless your toner cartridge is leaking toner (you?ll see toner on the inside of the printer or leaking out if you remove the cartridge and shake) a simple cleaning is probably not the answer. Let me know and we'll pick up later.
Feb 28, 2007 | HP LaserJet 4100n Printer
HP LaserJet 4100n Printer Logo
1,419 people viewed this question
Ben Johnson
