Question about Delphi Roady XT XM Radio Receiver
Radio works in home system, but not in car. Unit powers up, and display works as well, but no audio. Car will pick up audio from home system when parked in home garage. Is the base involved in transmittal of signal, and could the base then be the problem?
  • warren_howe Jul 02, 2009
    Antenna in vehicle must work, because display picks up song name/baseball score, etc. Speakers also work.
    Top Expert:
  • Delphi Master
  • 79,865 Answers
Sounds like you have an antenna problem, nothing else could cause this.
Posted on Jul 02, 2009
  • 813 Answers
Try connecting an extrenal antenna for better signal. check if the speakers of the car are connected properly to the unit.
Can set the time but not save it or display it
i would look at the red assesory wire that is to keep power in your head unit even when the car is shut off it is part of the memory for time, radio stations ext.some have fusable link in red wire,sometimes they blow out like a fuse.can be picked up at radio shack.its a cheap fix if thats what it is.some dont have link in red wire.if thats the case its inside the head unit.it is not keeping power in the unit once the car is shut off.FORGETS EVERYTHING LIKE A 90 YR OLD MAN LOL.PS CHECK ALL CONNECTIONS.good luck
Dec 22, 2010 | JVC KD-AR870 50W x 4 CD/iPod Ready/Sat....
I cannot get the radio to work
When you say "radio" I'll assume you mean the FM radio; perhaps the AM does work? There is usually a coax connector for the FM radio antenna, perhaps one was included with the set, perhaps not. Make sure it is installed properly. Tune your radio to a frequency that is local and that you can get easily with other radios in the house and car. If its not picking up that station, check your settings on the unit to see if there is something preventing reception.
Apr 11, 2010 | kawasaki 5-DVD Home Theater System - 1152...
L322 reg02 radio display not workin no sound on tv or sat nav. visual display working on sat nav and tv but no sound. seems as if there is no power to left hand side of unit. righthand buttons working but...
solved the problem after speaking to the main dealers, disconnected battery for fifteen minutes then reconnected which rebooted system. Range rover say just like your home computer its got glitches so rebooting works, common problem in cold weather.
Jan 13, 2010 | Car Audio & Video
My car radio aking for a code
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle (some people say that they find it on a sticker in the glove compartment, but I wouldn't count on that). If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release. The code will come up to two sets of numbers)
Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Nov 17, 2009 | 2004 Honda Accord
Display show 'No TP'
your arial might have come unpluged but you will have to get someone to take a look at it
Sep 02, 2009 | Sony CDX-4000X CD Player
Stereo not working, and slidind doors either. need fuse diagram
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
Audio Unit Self-Diagnostic Mode
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
May 25, 2009 | 2002 Ford Windstar Cargo
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
"buzz" when Sirius receiver is plugged into AUX input of new Camry
Did you have the unit installed at a shop that would have hardwired the power source? It sounds like either your power wire to the sirius unit is connected to a noisy power source (which is why you are picking up the alternator whine), or you have a poor ground connection to the unit. If it was installed at a shop, take it back and have them move the power source to the same wires that the radio gets power from. If you are using your cigarette lighter for power, unfortunately it sounds like your outlet doesn't give you the best source for powering an audio component. You might try stopping by a car audio shop and ask how much it would cost to hardwire the sirius' power to the back of your radio.
Nov 07, 2006 | Sirius Satellite Radio Sirius Starbase...
Delphi Roady XT XM Radio Receiver Logo
102 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
