Question about Whirlpool Refrigerators
Whirlpool Gold Conquest Model #G56SHEXNB00 Side by side Refrigerator side Lights out despite changing bulbs and temp control dial settings do not display. Otherwise, refrigerator & freezer works fine.
mikedurland
  • 481 Answers
SOURCE: Our icemaker stopped functioning. It
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad,
  •  or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  •  In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool gold Conquest side by side refrigerator-- water dispenser doesn't work but ice dispenser does.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
Posted on Sep 20, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Gold Conquest light is flashing and clicking sound
With sounds like that I would use caution if installing a light bulb there. The sound and description sounds like a short circuit. Did this happen recently? Could you get me the complete model number, for example GS6SHEXN
Let me know, Thanks Sea Breeze
Posted on Mar 21, 2009
Maytag317
  • 1136 Answers
SOURCE: Refrigerator light out
Hi, Did you try the old bublb in a lamp to make sure the bulb was bad? Sometimes when you put a new bubl in, it feels like it goes all the way in. Try tightening the bulb again. Use a rag and grab the bukb with the palm of your hand a turn. I have been on many of these that just needed a little more turn even tho it felt tight.
I hope this helps. If this does not take care of the problem, remove the light switch and test it for continuity.
Please let ne know if I can assist you further.
Vic
Posted on Jun 19, 2009
  • 56 Answers
SOURCE: Whirlpool Gold Conquest refrigerator side light
This may not be the problem now but by the sound of the malfunctioning electronics, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
Whirlpool refrigerator model GD5rha does not cool but freezer portion does.
replace the control board usually lights are out in refrige side also ans temp readout is also out part # 4334000 appliance parts pros $80.25 shipped
Oct 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights in fridge side are all out. After changing bulbs, sounds like a relay sticking and will knock out all lights in fridge unless we loosen off the bulbs in the fridge side
your main control board Part#4334000 is defective in lower left rear of unit remove it from the white plastic box and underneath it will have a burned spot on the printed circuit trace get it at appliance parts pros 1-877-477-7278
Sep 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights off
your switch could be sticking. or your bulb may be loose not allowing it to get a good connection i would check the bulb to make sure it is fully screwed in and than clean the switch area with a damp cloth.
Aug 15, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
175 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
