Question about Whirlpool Duet GHW9150P Front Load Washer
Door on washer will not open
I puchased a washing machine and ran a load of clothes through and now the door will not open. I think the machine is off balance. If i balance the machine and run it through a cycle again wil this unlock the door?
  • 18 Answers
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Posted on Nov 09, 2007
Smells musty and not washing clothes well
"In washing in the HE washers I think that if you have more than 3 loads a week you should maybe wash your washer at least once a week. I have started wiping the door off and leaving it open between washing and that helps a
lot with the smell.
This is why I think if you could wash the washer once a week it would probably do better. You never had this problem in the old washers." Try this in your washer.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Lights went out on my bosch washer and i cant get clothes out
I unfortunately was not able to get the service manual for this machine but as far as I remember there is an internal fuse in the bosch nexxt.
Will be lokated where the power enters the machine or on the control board.
Jul 16, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Can't Open the Washer Door---Our Clothes are held Hoatage
Check and ensure that the tubes and passages to the water level pressure sensor are not blocked by caked detergent, lint , etc.
( this may have caused the water overflow in the first place)
clean up the internal parts that are wetted by the overflow.
clean the door lock mechanism. ( this normally works on a temperature delay mechanism, if cleaning does not work, replace)
all the above done with the power unplugged and water inlets unplugged , of course
Apr 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Smely Clean Clothes
We had a similiar problem. It was mildew in the washer and in the fabrics. We ran two or three empty loads with some bleach added in, and we leave the door open so the drum dries.
The towels and clothes we hung out in bright sunlight. The UV rays kill the mildew.
Dec 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Sep 20, 2007 | Creda W120VW Front Load Washer
How to open door
how did you get the clothes into the washing machine in the first place?
Sep 16, 2007 | Estate TAWB600JQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
354 people viewed this question
Dan Webster
Dan Webster
Sal De
