The front door doesn't close properly, the release button on the left seems loose.
    Sergeant:
  • 210 Answers
Please can you tell me what brand of printer? Is it Konicaminolta, hp etc. I might tell you the toner cartridge or the drum carriage is not install properly or the interlock tab on the door is bent. This the best I can tell you because I have no clue what brand is your printer.
Posted on Jul 02, 2009
On a 207 G6 GT Pontiac retractable hardtop where is the sensor that gives the message top not secure. Top goes up and down seem secure will not allow the trunk to open with the key or door button
The retractable hard top is controlled by the folding top control (FTC) module.
Power Folding Top System Components
The power folding top system consists of the following components:
The folding top control (FTC) module
Hydraulic pump assembly; valve 1, valve 2 and motor
The hydraulic lines and the cylinders
GMLAN communication to the Body Control Module (BCM)
Open/Close request circuit to the driver and passenger window motors
Power and Grounds
Folding Top Main Power Fuse 30A
Folding Top Logic Power Fuse 20A
Ground G301 for the FTC module and G305
Folding Top Open/Close Switch (S15 and S16)
Rear Compartment Limit Switches
Rear Compartment Lid Release Switch (S3 and S4)
Rear Compartment Lid Release Switch-Front Hinge-Left (S11 and S12)
Rear Compartment Lid Release Switch-Front Hinge-Right (S9 and S10)
Folding Top Front Location Pin Guide-Left (S17 and S18)
Rear Compartment Lid Release Switch-Left (S19A)
Rear Compartment Lid Release Switch-Right (S19B)
Rear Compartment Partition Position Switch (S20)
Folding Top Front Location Pin Position Switch (S13)
Folding Top Front Latch Actuator Position Switch (S14)
Hall Effect Sensors
Folding Top Header Latch Cylinder Sensor (S1)
Rear Compartment Cylinder Extended Sensor (S2)
Your best bet is have the system checked for DTC'S - diagnostic trouble codes ! If it showed a message top not secured there is a DTC stored in the control module ! there are 24 possible DTC'S
May 29, 2015 | 2007 Pontiac G6 GT
2005 equinox left front window some times will go up and down , however most times times it seems to stick won't go up or down unless you help it to start moving. Should you stop it half way it seems to...
I have a similar problem with the same window. The window doesn't stop moving but it tilts forward until it won't close properly leaving a 1 inch gap between the top left corner of the window and the door frame from the perspective of sitting in the drivers seat. I had the motor and regulator replaced but to no avail.
I took off the door panel, everything looked fine. Took off all the weather strips and the driver side mirror. Behind the mirror there is the top portion of the metal guide the edge of the window rides up and down. it was partially cracked and bulged out beneath the crack. I gently pounded it back in and cleaned out the guides on both sides with window cleaner and WD-40. The issue will not be completely fixed until I replace the metal guide but it runs much smoother now.
Apr 30, 2011 | 2005 Chevrolet Equinox
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Bickley
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
My gas flap is stuck closed. We had to pry it open yesterday to fill the tank. 2 months ago the same thing happened, but it has worked since then.
If you have fuel door release cable & door is open, verify that cable moves in & out when you activate it. If yes you can adjust tab that it rests on so it will release properly. Just bend tab slightly inward at first, till it releases correctly.
Jun 14, 2010 | 2002 Volkswagen Passat
The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
Eric
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Automatic garage door
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
IP4300canon printer
The problem is that the ridiculously cheap little plastic piece on the door hinge that is supposed to trip the switch that tells the printer that the door is open is either a) broken off or b) no longer aligned so that it pushes the switch all the way. I solved the problem by removing the top cover and gluing the switch open with super glue.
To open the cover, find yourself a small, flat piece of metal (or stiff plastic) about 1/2" wide and a few millimeters thick. (A very flat-bladed screwdriver will do, but I made myself one out of the non-sharp side of a straight-edge razor blade.) Push this into the 5 slots marked with an arrow around the sides and back of the printer (they're toward the bottom of the sides.) Pry up on the cover at the back and then pull straight up on the front. There are two flat vertical pieces that slide into slots at the front that have to come up - they were tough to make come loose, just try not to break them off.
Pick up the electronic control panel that is on the front right of the printer. (You might have to remove the silver piece of plastic at the right front corner. It pulls straight up to remove.) The switch is the little black plastic piece on the left side of the electronic control panel. Push it to the "open" position (opposite the resting position) and glue it in place. Reassemble your printer and voila! no more annoying "door closed" message!
Jan 10, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
118 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
