Question about Freezers
Soft sealant should the sealant around the pipes that come from the motor to the freezer body be soft or runny?
  • 400 Answers
No it should not be sof and runny. Especially if you are talking about the armaflex insulation, I presume that some sort of solvent may have leaked onto the rubber causing this. It is made to withstand great temperature.
Posted on Jul 02, 2009
  • Shane Seaman Jul 02, 2009
Westinghouse wrs6r3ew2
Hi
Check if the refrigerant gas is enough. You can feel this on your compressor motor. if the one pipe from the compressor motor is hotter and the other has to be cooler/warm.
Feb 16, 2014 | Freezers
Freezer will not shut off some things frozen, bread and ice cream soft
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire freezer LFFU14F5HWN fan not running or cooling
Hi djgecko - Here are a few simple troubleshooting tips that may help you resolve this issue:
· First check clearances around your freezer. There must be adequate space around a freezer with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the unit.
· Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the freezer. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure the freezer is level and keep food and containers from blocking the door closing.
· Check the door seal. You do this by placing a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket. (Most appliance owners can easily do this without any tools or sealant.)
· Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
· Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the freezer will not get cool.
· Double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Apr 17, 2013 | Frigidaire 13.7 cu. ft. / 388 liter...
Food is frozen, ice cream is soft
Thanks for choosing FixYa and welcome to the site. Gary, I have seen this a lot myself and I have asked many people about this occurrence. The ice cream usually goes soft when the freezer goes into defrost mode. I would say this is what happened here. It always puzzled me and I finally asked around. I was confused because sometimes it was froze and sometimes it was soft. I hope this helps you out.
Apr 19, 2011 | Amana Freezers
Meat in freezer is frozen but ice cream and pop-sicles are soft and mushy
Most likely your condensing coils are dirty, or the condensing fan motor is not running. Pop the cover off the bottom of the fridge and look in there and see if coils are dirty. Clean off coils with coil brush, vac or coil cleaner. Also feel around the doors. Is it hot to the touch. If so these are the two causes. If Condensing Fan motor is not running then replace it. Some times the blade can be stuck on something. ( I have found a few with mice ) Clear problem and spin the blade. If it runs then you need not replace motor. You may need to replace blade if it is bent and not turning freely.
May 15, 2010 | Frigidaire Freezers
Suction line on walkin freezer is sweating from condensor to evaporator above ceiling
The insulation wrap around it needs to be replaced. Thats the black foam stuff around the pipe.
When it gets old it loses its insulation quality and the the humidity condenses on the pipe.
Wrap it well in new insulation ensuring that all seams and openings are taped, and every square inch of pipe is wraped, but not to tightly. (Compressed insulation lowers efficiency)
Aug 26, 2009 | Freezers
Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Jan 11, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Proline Freezer upright /not freezing down very well
Defrost it and see if you have lost the insulation aroundthe pipe. If you have you can use expanding spray fome insulation on it. like you use on your house.
Dec 27, 2008 | Freezers
Meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Warm freezer
seems to me that the freezer control motor is not pushing the freezing gas around cooling the unit. Suggest an engineer.
Thanks J
Jan 26, 2008 | Engel Freezer Portable Freezer & Warmer
Freezers Logo
42 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
