Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
How to change spark plug on McCullough eager ****** 16 chainsaw
  • bjnliles Jul 04, 2009
    Thanks for your help, but I did not ask the right question. I had never worked on a MCCullough chain saw before, only lawnmowers, etc. and electric chain saws. This chainsaw was given to me as a challange to get it running.
    My problem really was: how do you get to to the spark plug to examine it and then check to see if it is getting spark from the magneto.
    I didn't realize you had to remove the chain and bar cover to get access to the spark plug. This is not easy to reassemble either.
  • Anonymous Mar 15, 2014
    Cannot reassemble choke assembly on McCullough eager ******
    Brigadier General:
  • 4,088 Answers
The hardest problem is pulling the wire boot off of the plug--I use a screwdriver to lift up on the boot while pulling on the upper boot with your fingers and twisting the boot side to side. Once the boot is off, use the proper size deep-wall socket wrench to remove the plug (turn counter-clockwise). Make sure the base of the plug near the cylinder head is free of dirt. The plug is a tapered-seat type and is prone to being hard to turn at first. If the internal insulator is a shade of brown, it is probably ok. If it is oily black, then you are probably putting too much oil into the fuel mix, or using automotive oil. Check the spark by installing a new plug into the boot and run the starter a few times. There should be a blue spark occur each revolution (the plug base must touch the cylinder head!).
Posted on Jul 03, 2009
  • drallim Sep 11, 2009
    I was reviewing some former answers to problems and read your response. By now you have realized that the spark plug is not under the chain drive cover, but is at the rear of the saw--the point nearest you when holding it to saw wood. See the previous entry for procedure to remove and check the plug. Make sure the ignition switch is in the upper position to get spark. If you get spark, try squirting a little starting fluid into the plug hole, reinstall the plug, and pull the starter cord through a few times. If it runs for a second or two, turn the choke lever toward the side and pull the starter a number of times until it pops, then turn the choke about halfway back, and pull some more. If it won't do anything, then there is no fuel getting to the engine. Make sure that there is fresh fuel/oil (40 to 1) mix in the fuel tank. Both case halves must be removed to gain access to the carburetor and fuel tank if you plan to get into the carburetor.
How to test spark on McCullough 2.0 chainsaw
I would do it this way:
1) Remove spark plug, make sure it is clean, dry, and has the proper gap.
2) connect lead wire to plug
3) hold plug against motor next to spark plug hole.
Make sure you have a good contact or you may get a jolt in step 4
4) pull starter cord rapidly while looking at tip of plug
Spark should be strong (hot), and Blue colour
Jun 18, 2015 | McCulloch Garden
How do I change spark plug in my chainsaw
find where spark plug wire is connected to plug and disconnect very gently, remove spark plug with proper 13/16 or 5/8 wrench or socket and replace with new spark plug
Sep 16, 2014 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
McCullough Eager Beaver model#40010205 392 chain saw manual/parts
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 19, 2012 | McCulloch 14" Electric Chain Saw Mcc1514
Need manual 14" mccullough electric chainsaw eager beaver
McCullough 14" Electric Chainsaw User Manual
(NOTE: This is also useful for the EagerBeaver Electric Chainsaw)
Online Manual:
http://www.manualagent.com/mcculloch/ms1415/users-manual
McCulloch MS1415 User Manual
PDF Manual to download:
https://libr2.com/get/mtd-ms1415-2409
Oct 24, 2012 | Garden
Spark plug gap for Mccullough 2.0 eager beaver chainsaw
Refer to your service manual.
Contact us
User manuals
McCulloch Service
Jun 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Eager ****** McCulloch Chainsaw; Won't start when hot...
Loosen the fuel cap just before you shut it down. Close it just prior to restart. If that corrects it, there is a fuel vent problem. HTH
Lou
Oct 05, 2009 | Garden
I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Jan 11, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Change Spark Plug on Eager ****** Chain Saw
yea you have to take it apart sorry
Oct 06, 2008 | Garden
CHAIN SAW MANUALS
Counterclockwise. Pull the spark plug and stick a length of 3/8 yellow nylon rope in the hole to keep the piston from turning. While you have the clutch bell off check the rim sprocket as well. Good luck!
Aug 30, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
200 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
