Hard drive failure
I have a Freecom 500 Gb USB drive that has failed. There is no activity of any hdd activity, even though the power light shines. If I managed to buy another drive and swop the new circuit board over onto the faulty drive, do you think it may solve the problem?
  • 5 more comments
  • Ragav Dec 21, 2007
    I have a Simple Tech Pininfarina 250GB external hard drive, it dosent seem to be working. Even though the power light is being displayed, the system is not detecting the hard drive. After i switch the power on, the disc makes the whinning sound and there is no problem with the cables as I tried the same cable with an another hard drive and it works perfectly well. Please help me out here, I have lots of important data in this disc and dont want to loose it!!
  • lapi_98 Jan 03, 2008
    I have a simpletech Pinifarina 250GB USB HDD. The light comes up and I can hear the HDD spinning. The computer asks me for the driver otherwise it will not recognize it. It will appears as an unknown device...too much data that i cannot lose...
  • billyf2k Jan 13, 2008
    I have the Fantom 500gb drive. It failed 6 months afer the warranty lapsed!
    I opened the case and disconnected the hard drive and checked it with a drive adapter. Fortunately, all my data was on the drive. Ive isolated the failure to: 1/ usb connection, 2/ circuit bd 3/ Something else.
    I'm thinking of purchasing a new enclosure or is it worth trying to replace the circuit bd etc. any thoughts anyone?
  • Anonymous Dec 04, 2008
    My 160gb segate has a small 160LME component damaged i cant get any replacement also what do i do? Please suggest
  • Ty07 Dec 16, 2008
    My problem is I know that the power supply in the drivezilla 1tb enclosure. Does anyone know where I can find the specs to the power supply or where I can find a replacement?
  • Anonymous Jan 03, 2009
    Power light comes on. System recognizes USB as 3200 Maxtor, and USB Mass Storage device but device fails to initialize (This device cannot start. Code 10). Looks like the blinking light that notes disk activity doesn't flash. Appears microcode (identify of Maxtor 3200) is okay but possibly spindle is frozen. Tried hour-in-the-freezer trick with this USB HDD, not help. Tried deleting C:\WINDOWS\INF\INFCACHE.1 also no help.
    Any ideas? Two years of pictures are at stake.
  • hamcoco Mar 27, 2009
    Hello, I've also a Freecom 500Gb external drive.
    Mine just switches off. Leaving the computer searching for it.
    It's been to the hardware-boys and they told me that on the hardware side nothing was wrong.
    Reading some of the solutions I will have a look inside.
    Scholar:
  • 38 Answers
If the board is the problem, perhaps. But often a drive failure is a head crash, in which case only data recovery services can help. Before you take apart the drive itself, make sure it is not a simpler problem-- one inside the enclosure.
There are a couple different possibilities here. 1) The hard drive has died. 2) The power supply for the external enclosure has died. 3) The controller circuitry for the enclosure has died. To determine what is the problem, you'll probably need to open the enclosure. Chances are, if the power light comes on, the power supply is working in some capacity.
Disconnect the drive's USB cable from the computer, and turn off the drive, usually with a small switch on the rear.
Now, place the drive flat against your head so that you can listen to the inside. Do not make any sudden moves at this point, shake the drive, drop it, etc. As the drive turns on, it is susceptible to damage.
Turn on the drive and listen for a "whirring" sound that indicates the drive is spinning up. After the initial spin up, it will become quieter. Make note of what you hear, and turn the drive off-- put it down after a few moments, giving the drive time to spin down again. A drive that is powered up can be damaged by handling it roughly.
If you did not hear the drive spin up, proceed with opening the enclosure.
If you heard it whine as it spun up, the problem is more likely with the cable you use to connect it, or the drivers/hardware in the system. Replace the USB cable. Uninstall your USB interface/hub inside the Devices control panel and Scan for Hardware Changes-- this may reload corrupted USB drivers.
Opening the Enclosure - First unplug the drive.
Open the case. Generally this is by removing two or more small phillips head screws on the back or bottom, sometimes they are covered by rubber feet
The outer shell will often pull off of or slide away from an inside chassis.
Carefully open the enclosure, taking care not to disturb cables. You should immediately see a fuse on the power supply you can check for replacement.
At this point you should also check to make sure the ribbon cable and power leads are firmly in place.
On the PCB (printed circuit board) look for burned or scorched areas, bulging or split capacitors (small, colored "can" looking components soldered on)-- also, is there a burnt smell?
If the fuse was blown, see if replacing it solves the problem. If the power connector and/or ribbon cable were not inserted fully, or were loose, unplugging them and then re-inserting them firmly may solve the problem.
If there are bulging capacitors, a smell, or discoloration, the power supply may be bad. Replacement enclosures can be purchased online for under $30. Be sure to get the right size (5.25" or 2.5" drive?) and interface (IDE or SATA).
If none have these have helped, the drive indeed may be bad. Many drives like these are under warranty. Look for the manufacturer's name and website on the drive. Most makers will have warranty information displayed prominently on their support page. They will often allow you to enter the drives' serial number to determine if it is under warranty, in which case they will issue an RMA (Return Merchandise Authorization) for repair or replacement.
If the drive is not under warranty, you can still purchase a "bare" OEM drive of similar capacity for around $110, and replace it yourself. Take care to purchase the right type of drive -- most are IDE but some are SATA. A wide ribbon cable means IDE. Simply make note of how it is installed in the enclosure (usually a couple screws) and mount the new one the same way. Close up the case and re-connect it to your PC.
Posted on Nov 09, 2007
Open the case and you will find a standard ATA or SATA drive with a SATA to ATA converter. Most likely the converter has gone bad. You can buy a external converter(IDE to USB) from the market (I have one without a casing which converts 3.5 and 2.5 to USB and I got it for $10) connect the converter to the drive and it will work. You will be able to recover your data.
Hope it helps
I have just acquired a 500 GB USB HDD and its NTFS formatted, it doesn't show when I plug in SONY BRAVIA USB port
I think it should also come with a power supply also.Does it have lights on it. Try a different port.
Mar 05, 2012 | Computers & Internet
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
500 GB HD stopped working
plz check the drive spin up when u connect to power
dont use front panel usb plz use back panel USB
Jun 26, 2010 | Buffalo Technology (USA), INC. - 500GB...
USB not recognized
if the usb ur using is 1.0 - it can read it - get a 2.0 external unit and you're good to go.
May 02, 2010 | Freecom 80 GB USB 2.0 Hard Drive
My Fantom II Hard drive only has a red light on
Sounds like the drive has gone faulty, all you can do is take drive out of case, get USB to HDD - USB "Dongle" and hook up HDD, and see if it works on PC & USB, If YES, then Case and interface are faulty, otherwise the HDD is faulty.
May 01, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Suddenly stopped working
i think your hdd is dead,Because your hdd light not even turn's on....
Apr 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
We purchase western digital 500 gb hdd when pc is
The blinking of the lights is just the indication that data is being accessed.
Mar 19, 2010 | Western Digital My Book Essential Edition...
I installed a new WD Cavier 500 Gb hasr drive ot
Your problem could be that the hard disk is not ACTIVE.
Boot up with a DOS disk (floppy or CD or USB) and run FDISK, select 4 to Display Partition Info. If the C drive does not have A under Status then press ESC and select 2 to Set active partition and then set Partition C to active.
Sep 06, 2009 | Western Digital Computers & Internet
Hard appears to be dead
Microsoft has several methods to fix USB devices not recognized by PC. Click on the link below and scroll down to the Resolution section. Hope it all works out for you.
Greg
http://support.microsoft.com/kb/871233
Jun 06, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Computers & Internet Logo
2,203 people viewed this question
David Payne
David Payne
