Question about Acer NSK8458AN Keyboard
Symbols gone crazy
I discovered this same problem when I couldn't get quote marks or apostrophe. Finally sat down and went through the entire keyboard straight, while pushing Shift and while pushing Fn. Discovered that almost none of the symbol keys is where it should be. I did find quote marks and apostrophe, but have to hit Shift comma and Shift period, to get them. Have been in touch with Acer techs, but nothing they've suggested has worked (removing and replacing battery), reinstalling keyboard driver, installing some chipshift program or something like that. I've also checked the number lock and shift lock and they were not on. Sticky keys and toggle keys were off. language was set for Canadian English, and though I tried British and US English, neither worked. Nothing spilled on the keyboard, and nothing was installed other than Firefox browser.
  • 410 Answers
The keyboard appears to be defective, but if you replace it and you still have issues, then the matrixing chip on the motherboard is bad and you will have to change the motherboard as well. Let me know, and vote.
Posted on Jul 03, 2009
The @ symbol won't work and will only print as a apostrophe
Try using the ALT Car key to the right of the space bar.
Nov 25, 2013 | Samsung Chromebook Series 3
How can i type latter Apostrophe with dell laptop
Apostrophe key is next to the enter key
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 07, 2012 | Computers & Internet
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
When I press apostrophe quotes they don't appear. But when I press the button a second time, then I get double ( "" ) and have to backspace to get single quotations ( " ) How do I fix this?
Download the Microsoft settings utility for this keyboard and check through the options settings, especially for "smart quotes." The smart quote, if enabled, may not show up at either end of the quoted phrase until you press the apostrophe/quote key the second time; then both will show in their proper places, and one of the quote marks will be inverted (a nice style touch, if you want it).
Nov 18, 2010 | Microsoft Wireless Optical Desktop 1000...
My phone screen has went white!
The problem with your phone is that the flex on the screen of your phone is damaged.
All you need to do is to change the flex on the screen of your phone and you will see that your phone will start to display back.
Just change the flex on the screen as advice and you will see that the screen of your phone will display back.
Take care.
May 18, 2010 | LG VX8300 Cellular Phone
No apostrophe when texting
you can get all the symbols my pressing ' # ' (hash button) for 2 seconds while typin the sms..
Apr 30, 2009 | Samsung J700 Cellular Phone
Cannot get apostrophes or question marks
I just figured this out. Hold down your left shift key, then press CTRL. It may take a couple of times for it to work, but it will eventually.
Oct 08, 2008 | Compaq Keyboard
Apostrophe??
we have same problem before. :D
well when you're doing text message
you can actually press on the number 1 (7x) and u can get the apostrophe.
Mar 26, 2008 | Samsung SGH-D900 Cellular Phone
Messed up keys
try hitting the left alt and the left shift button together, then try it out by pressing shift question mark. I had the exact same problem and i think you can alternate between french and english keys by hitting these two buttons together.
Jan 18, 2007 | BenQ X805 Wireless Desktop Companion Pro...
Acer NSK8458AN Keyboard Logo
692 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
