Question about Sherwood RX-4105 Receiver
My speakers shut fown briefly even at small volumes. Help!?!
I have two Athena Technologies speakers. I have hooked them up to a Sony stereo -- nothing too powerful or fancy. When I try to listen to music at volume over 12-15 (out of 60!), the speakers shut down for 1-2 seconds at a time all throughout the song, unless I turn the volume down to under 10. It's very annoying. Do you have any idea what may be wrong with them? Thanks so much.
  • esmoris Jul 02, 2009
    Thanks for the quick response. The ohms are not the problem. But I don't have an amp. Should I install one? I used to have a Sony amp, which I got rid of. But back then, when I had the speakers connected to the amplifier, the amp itself would shut down when I turned up the volume (again, I never turn it up too much -- never more than 20 out of 60. I live in an apartment).
  • 52 Answers
Are the hooked up correctly positive and negative whats the ohm load of the speakers and amp could be a short in your speaker cables
could be many different problems
Posted on Jul 02, 2009
  • eazzeo Jul 02, 2009
    did the sony say anything on the display like overload or something when it would turn off?
    also where the big speakers or just book shelf models?
    maybe there was not enough power to push the speakers properly
    buying an external amp would not be worth it in your case if your in an apartment
    i would think just a simple receiver or surround sound unit would power them just fine
    i do know that some companies are mimicking the athena look and name but the speakers itself are not a stable ohm load an can fry your amp they even go as far as putting bags of sand in them to make them feel heavy
Stereo shuts off at 69
This could be due to the systems overload protection kicking in, which under normal circumstances shouldn't happen, I suggest moving the speakers next to the amplifier and if possible use anew piece of wire to test the speakers start with one and test each individually. I think you possibly have a small short in one of the wires. Or one speaker is damaged. Measure the resistance between each speaker wire pairs. The speaker will probably be either 4 or 8 ohms check that this is the case. Read the speaker labels for clues. Were they the original speakers supplied? by the same manufacturer?
Dec 07, 2013 | Denon AVR-1513
I am using Sony Vaio VPCEA24FM. I have facing some issue with the sound . My laptop's right speaker is not working. I have checked the volumne balance and even lowered the left speaker volume and kept...
Hi....Just check the sound with stereo headset.If it is working properly ,right speaker has to be replaced.If the situation persist same before,you may have to check the motherboard .
Aug 12, 2011 | Sony VAIO Notebook
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
May 10, 2010 | Yamaha P2500S Amplifier
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
I have hooked by two bose 161 speakers using 14 gauge speaker wire (about 8 feet) to sony str-dg720. But I get absolutely no sound from the speakers. I have hooked the speakers to port A set of input...
You gots ta isolate the problem.  Disconnect the speakers and hook them up to a stereo you know that works.  If you don't hear sound coming out of the speakers, then you know the speakers are fu.k.d up, so you need to look on the speakers to see if there is a fuse that is blown that needs to be replaced.  If you got sound coming through, then disconnect them and hook them back to the original stereo making sure you got a good connection and all the wires are in good and tight.  Then turn your stereo on and go through the various channels like Tuner, Tape Deck, Aux, and DVD to see if you get any sound.  Also turn the volume knob up. If you don't get any sound after all this, you know there is something wrong with the stereo your using.
Oct 29, 2009 | Sony STR-DE685 Receiver
My left speaker to my Sony HCD-GX450 stereo is
Make sure that Loudness switch is turned off & bass is not boasted up. Most cars have small cheap speakers that can't handle the bass. also its better to cut the low frequency from the woofer using a passive or active crossover. Most nowadays head units have got some sort of built in crossover. Refer to your head unit manual.
Sep 20, 2009 | Audio Players & Recorders
I HAVE A CERWIN VEGA CLS-15S POWERED SUB AND A PIONEER RECEIVER WITH NO RCA SUB HOOK UP ON BACK. HOW DO YOU HOOK IT UP
flathead30,
This is an old question but if you have not yet figured anything out, hear is a suggestion.
Without buying any other electronics, use your tape output on the receiver and let your sub's built in crossover to filter the highs out of the signal.
-Chris
Apr 16, 2009 | Athena AS-F1 Main / Stereo Speaker
Volume controls will not work
Look underneath the athena system, it should have a model label.
Jan 11, 2018 | Athena AS-F1 Main / Stereo Speaker
When volume is turned up the radio shuts off
Have you checked all of the connections on the speakers, stereo, etc. Being a marine CD player, the wires and connectors are exposed to more elements than a car CD unit. Check for corrosion and make sure that all the speakers are hooked up to the correct "+" and "-" terminals. Not sure if this will help, but thought I'd try. It does sound like a speaker connection problem.
Aug 30, 2008 | Clarion M255 AM/FM Marine CD Player
Stereo static
shut down all electrical sets around and check if the static goen the problem will be in electrical sets and you have to check it one by one.if it is not solved check your cables for any bad connector -open circuit- short circuit(try with a couple of new cables).-apply a contact cleaner in all sockets and move jack in and out in all sockets(with no power on)
Jun 12, 2008 | Audio Players & Recorders
Sherwood RX-4105 Receiver Logo
175 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
