Question about GE Profile Prodigy WPSE4200A
Lights but no action
I have a GE Profile Prodigy which is about 6 years old. It stopped working working during the final spin cycle, snapping the circuit on the breaker box. When that was reset and the plug was pulled, allowing for the electrical to reset on the machine, all that happens now is the lights come on, as if it is willing to do something, but that's about it. Water won't run, won't spin, zero. Any suggestions as to what this could be? Potentially major expensive repair (motor or something?), or minor thing? The manual that came with the machine is next to useless.
    Scholar:
  • 196 Answers
Sounds like a faulty control board. This board controls ALL functions of this machine. This can be a major expense for the age of the machine.
Posted on Jan 12, 2008
Spin cycle stops and moter humms
clean the filter out may be clogged
Jun 16, 2012 | GE Profile Prodigy WPSE4200A
Reattached tub, but spin cycle doesn't work
the belt might have come off of the tub take it back apart and look underneath and see if the drive belt is loose or on the floor when the tub came loose it probably slipped the belt off before stopping.
Dec 12, 2007 | GE Profile Prodigy WPSE4200A
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
Agitator keeps coming off
More than likely the plastic tabs that hold the agitator on are worn or bent to the point where they won't hold securely anymore. It's probably a good idea to go ahead and replace the agitator before it comes off during the wash cycle and damages the washtub.
Jun 07, 2007 | GE Profile Prodigy WPSE4200A
Will not drain during spin???
Most likely your outlet filter of the machine is choked with dirt or something; clean out the filter & refit. Of course after taking of the wall plug & siphoning out the water from washer.
Sep 21, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
142 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
