Question about Frigidaire Refrigerators
How do I pull out tray behind toe grille to clean?
Model number is frs23r4a
  • Official Brand Answer
  • 2,267 Answers
Hello Friend, this is Z. Thank you for allowing me to assist you!
The drain pan of your Frigidaire refrigerator (FRS23R4A) is not removable. Hope this helps! Should you need further assistance please feel free to reconnect.
Posted on Sep 10, 2014
2 Suggested Answers
ApplianceDOG
  • 57 Answers
SOURCE: Model FRS23R4A - loud
Somebody hiding in your freezer? Na, I'm just kiddin! Sounds like an evap fan going bad on ya. Eventually you will need to replace the fan!
Thanks and please rate me!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Posted on Aug 26, 2011
My fridge is freezing up, what can cause this problem
Get make and model number look for a replacement bi-metal switch or thermostat
Jul 26, 2012 | Frigidaire FRS23R4A Side by Side...
Model FRS23R4A - loud humming noise coming from inside freezer section at top behind the ice maker. What might this be?
Aug 26, 2011 | Frigidaire FRS23R4A Side by Side...
Hello I have frigidaire frs23r4a, when I plug it
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If this doesn't work Do this
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | Frigidaire FRS23R4A Side by Side...
I have a frigidaire model#frs23r4a side by side fridge the ice maker makes very little ice and is not working at all now, any repair suggestions ??
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...thumbs up
Aug 17, 2009 | Frigidaire FRS23R4A Side by Side...
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Frigidaire Model # FRS23R4A - Not cooling
wihtout replacing the relay there really isnt any way to tell if its the compressor or the relay. the relay is veyr inexpensive in comparison to the compressor usually less than 70 bucks. and the best part is you can replace it yourself as opposed to paying a service company. this is the part number 218721113 and it prices at 38 dollars thru  sears.com.
once you replace the part if the compressor starts you should be ok. if it doesnt start then you will need to call a service company to replae the compressor or look at replaing the refrig. if the unit is less than 5 years old it may be under warranty for the compressor so check into that first. if I can be of further assistance dont hesitate to ask. thanks Peyton
Mar 08, 2009 | Frigidaire FRS23R4A Side by Side...
COMPRESSOR
If you are in the USA
A compressor must be replaced by a certified refrigeration technician due to federal laws about proper handling of refrigerant. Also, all the joints must be soldered together with a torch, this is not a job for an amature.
If the fridge is less than 5 yrs old it should still be covered by the sealed system warranty and repaired at no charge.
I do know that the compressors for many of the SxS fridgidaires have been on back order due to a change to a different brand of replacement compressor. I recently waited 2 1/2 weeks on one I had ordered for a customer.
Once the tech has the compressor it is usually about a 2 hr job to replace, depending on the model.
Most of the parts dealers you contact will be hesitant to sell a compressor to someone that is not in the repair buisness, due to warranty claims if it is not installed properly. If you want to get one yourself you should be able to order it through Sears if you can't find it anywhere else. Go to sears.com, click on parts and enter the complete model number from the sticker in the refrigerator. If your model isn't listed you can call the 800 number on their site.
Hope this helps.
Nov 06, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23R4A
no cool but copressor running
Jun 01, 2007 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
