Question about HP PSC 2175 All-In-One InkJet Printer
When turning power ON, a clicking noise coming
Will not print. When turning power ON, a clicking noise coming from under keypad will continue for about one minute and then stop. The scan,copy, photo card buttons will then flash continuously until turned off. Problem repeats when turned on again. Thank you for any help you can offer.
Michael Farinacci
    President:
  • 2,306 Answers
Sounds like the scan assembly is worn out. If you lift the cover where you lay a copy and watch the scanner after youpower up, you might see the scanner just clicking back and forth, which means the lamp is worn out or dirty. Repairs in that case are more than the machine is worth.
Posted on Jul 02, 2009
I was copying a fairly large document and at some point the document continued to scan but stopped printing. The memory light is on and the LCD print out reads "printing" but it is not printing.
hello there, Sorry but the question is a bit confusing. Did the document finish copying or it copied half way and stopped? Or you were copying and printing it at the same time?
If you were copying and printing at the same time then the problem is expected as the procedure for printing is considerably faster than the copy process. Simply turn of the entire system either by proper shutdown or by just cutting the source of power to the unit. And this time copy the document completely first before you try printing. This should come up without any hassles.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 04, 2011 | Office Equipment & Supplies
Hi, the scanning function is not working, when I press to scan a page it starts making funny noise for about 1-2min and then stopped without doing the scan. Any help appreciated, thanks
Do you experience the same problem when making a copy? Try to unplug and re-plug the printer into the power outlet to reset it. When the printer turns on, try to scan or make a copy again. If problem continues, please contact Lexmark technical support for additional assistance.
Jun 20, 2011 | Lexmark X6570 InkJet Printer
I have a Brother MFC-9840 that comes up with Print Unable 21. I have cleaned as set out in maintenance to no avail. Please help. Thank-you
The MFC-9840 manual says that this code is reporting a mechanical error.
Try to reset your machine in maintenance mode:
menu * 2 8 6 4 (within 2 seconds)
91 and then 99 to exit service mode.
User manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_9840CDW_EN_2378.PDF
Brother's suggestion:
Turn off the machine's power switch and then
turn it on again. If the error message continues
leave the machine for several minutes and then
try to print, copy or scan again
Good luck.....
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 15, 2010 | Brother MFC-9840CDW Laser Printer
Suddenly stopped scanning and now won't copy or print b/c keeps saying it's still scanning. Canon mp830. Scanning Wizard starts but just dies in the middle. Any button I'm not hitting or solution you can...
Any lightning strikes locally?
You can try to reset back to factory by removing cartridges and head.Power off unit ,then unplug for 45 minutes.repower and install all.
Do a nozzle check and see what happens.
Aug 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Have Ultra Hi-Definition RX595 Photo all-in-one print,copy,scan,photo. After setting everthing up and when I print from word or anyting the print comes out in color. I thought I could have color or b/w...
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Aug 21, 2008 | Epson Office Equipment & Supplies
Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Aug 05, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    Printer
    One of the best solution that we can provide you is head cleaning. One of the effective method of Head cleaning is listed below.
    1. Make sure the printer is turned on but not printing.
    2. Load letter size paper.
    3. Click on START. Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu.
    4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
    5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
    6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
    7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
    8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
    9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
    If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) , your printer will require service.
    Jun 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
    HP Laser Jet 3300 constant noise
    I had the same problem. After updating a hp firmware, so far so good. The noise is gone.
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=66367&prodTypeId=18972&prodSeriesId
    =66359&swLang=8&taskId=135&swEnvOID=54
    That is the link for the 3330. It is under the downloads section and is at the bottom. They refer to it as firmware
    Nov 08, 2007 | HP LaserJet 3300 All-In-One Printer
    Priner doesn't want to scan, copy, or print
    The only thing I can really suggest is that you reinstall all the software. If it persists you should get in touch with HP, use your warranty if valid. On uninstalling and installing the software: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=79488&lang=en&docname=bpu05205 Good luck
    May 13, 2006 | HP PSC 2110 All-In-One InkJet Printer
    HP PSC 2175 All-In-One InkJet Printer Logo
    355 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
