Question about Logitech Z-2300 Computer Speakers
Output port for left speaker Z2300
The sound coming through the speaker connected to the left output port is faint. There is barely anything coming out of what. What could be happening here?
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
Posted on Jul 24, 2009
I have xr 1220 an no sound output?mixer is working but no sound output to the speakers.
If there's a cue output on the unit, use this to make sure it's actually outputting a signal.
Just put some headphones in the cue port and see if there's anything.
If there is, it may be a problem with your speakers or how you've connected it to your speakers.
If all else fails, it'll be your output board in the mixer that's the issue.
Good luck & have a great day! :)
Jul 12, 2017 | The Music
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
I got a new motherboard, and the back only has a pink, green, and blue color for the jacks. However, these logitech speakers have a green, pink, orange, and black. i have the green and pink in and my...
PINK -- if you have a microphone, connect it here
GREEN -- if you have a headset, or you have external speakers, connect it here,
to get 2-channel stereo output ("left" and "right").
BLUE -- if you have an iPod (or iPod Touch), or audio-cassette player, and you want to feed the "audio-output" from those devices into a program that will record the sound on the "line-input" port on your computer, then you need to connect this port.
Since your new motherboard does not support 5.1 audio-output, you need to purchase a sound-card that has GREEN and PINK and ORANGE and BLACK sockets, so that you can get sound into the "middle" and "back-left" and "back-right" speakers.
Or, just connect the GREEN, to use your speakers in two-channel mode.
You'll also need to access the web-site for the manufacturer of the motherboard, to download the correct device-drivers for the audio-hardware embedded onto the new motherboard, in order to get _ANY_ output out of your sound-card.
Feb 17, 2011 | Logitech G51 5.1 Multimedia Surround Sound...
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
I plug in small speaker but only faint sound come out are the speaker output also amplfied pb10 230
Depends on what, if anything, is connected to the High Level speaker inputs. The High Level outputs only pass on what is being fed to the Sub from your amplifier or receiver. The sub's internal amp is for its use ONLY.
If you're using the Sub's internal amplifier and feeding it the LFE or Subwoofer Line Level output of your amp or receiver via RCA cables, I'd be surprised if anything is present at the speaker terminals on the sub. It shouldn't be.
Mar 04, 2010 | JBL PB10 Subwoofer
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
Z-2300 Left Speaker and port dont work
did you try plugging in the other speaker into the yellow output. If you can hear music doing that then its only your left speaker that is the problem. Try tapping the faulty speaker into the palm of your hand while connected. There might be a faulty contact to the actual cone of the speaker. I had to open mine up because i had the same problem. It turned out that it was the wires that weren't making contact. I scrapped and moved them around connected the speaker and it worked. I hope that i made some sense out of this. good luck.
Sep 06, 2009 | Logitech Z-2300 Computer Speakers
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
No Sound Right Front Speaker
Sounds (forgive the pun) like that channel's power chip is gone. Take it to a Tech, I may advise...
Mar 29, 2017 | Audio Players & Recorders
Logitech Z-2300 Computer Speakers Logo
491 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
