Question about Symphonic SR90VE
No picture and no audio
There is power, but nothing show on the screen I see the lights on the sides of the screen white, no picture or sound.
Symphonic wf32l6
  • georgemv6060 Jul 02, 2009
    I can't get anything on the screen, including the setup menu or anything else for that matters.
  • 749 Answers
You need to change the wire connecting from the player to the tv, the SCART lead.
Posted on Jul 02, 2009
    President:
  • 1,383 Answers
First reattch all connection to it.
Then reset all settings to factory defaults.
  • kishor
    kishor Jul 02, 2009
    It has some circuit and hardware issue it needs service.
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
LN32B360 no picture
does the display totally black or white screen then how about the sound still working.
Sep 07, 2012 | Samsung LN32B360 32 in. LCD HDTV
Screen is white
This type of problem is usually caused by a failure of the power supply board. The power supply puts out 5v and 12v to the electronics. If the power supply 5v side fails then the electronics does not get the right power but the back lights do so you get a white screen and no picture. The audio electronics are powered by a different power output. Here is a link to a repair guide for the Q19w that shows how to dis-assemble the unit and then which capacitors need to be replaced to revive the unit.
http://www.ccl-la.com/blog/index.php/how-to-repair-a-optiquest-q19wb-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Nov 30, 2011 | ViewSonic Optiquest Q19wb LCD Monitor
Power comes on but it only shows a blank screen. screen shows nothing at all no menu, nothing. tv works fine.
Make sure the video/audio cable is plugged in correctly. Red cable into red socket, yellow into yellow and white into white. It is easy to put these cables in the wrong socket by accident and will cause no image to appear on your screen.
Jun 12, 2011 | Video Game Consoles & Games
Turn on tv, no picture no sound, shined light into screen,nothing
Check your connections and scart leads, take them out and put them in again. It may be a loose lead or maybe a faulty lead, swop them over to see.
Apr 28, 2010 | Olevia LT32HVM 32 in. LCD Television
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
Same problem KDL-40S2000, no picture on any input, but do get sound. Picture glows when powered on and if I tap the back or sides I get white flashes on the screen, but nothing shows on the screen.
I would replace the bulb.Sounds like it maybe bad,I would try to reseat the bulb then if that doesn't work then replace it.Do any of the power buttons flash when you turn it on?
Mar 12, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Repalaced bad capaitor(bulge on top) Now powers up. snowy with sound and picture goes blank. With nothing on screen. Tried to use remote but nothing shows up on screen. Note the snow is from not being...
When the filter caps went bad, the power supply output will be AC and feeding the circuits which can damaged the parts on the board. Check to see if you have the 12 or 18v feeding the back light invereter board. There are surface mounted fuses on the inverter board also. Send me good pictures of the whole back where all the boards are and close up picture of the inverter board, may be I walk you through. budmrtn@aol.com
Dec 10, 2009 | Westinghouse SK-19H210S Television
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
Symphonic SR90VE Logo
53 people viewed this question
Top Symphonic Televison & Video Experts
SHARCNET-USA
SHARCNET-USA
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
