Question about Frigidaire GLEQ2152ES Electric Dryer
I have a squeeky noise coming from the back of my dryer model GLEQ2152EE0 SERIAL XD71313287. when i push on the back of the dryer in the central location it goes away then comes back
    President:
  • 1,723 Answers
The belt that turns the drum needs to be replaced. You can do it yourself. Take the back off and you'll see it. It is a bit tricky.
Posted on Jul 02, 2009
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Oct 29, 2015 | Frigidaire Dryers
Dryer makes squeeky noise when drying
What brand is the dryer and is it front load
or regular?
Apr 20, 2014 | Kenmore 800 7982 Dryer
LG dryer model dle3777w. Squeeky dryer. Maybe the dryer rollers can replacement parts be ordered?
Just to be sure, try spraying some WD40 or similar grease on the shaft of the rollers. I noise goes away, place heavier grease or replace the rollers.
Oct 18, 2013 | Dryers
LG Dryer 3828el3003b. Very squeeky noise when dryer is running. Could it be the drum rollers and how can I fix them?
Place heave grease on shaft of roller wheeles or replace the rollers.
There might also be bearings at the back of the drums. If they are there they will also leak. Spray grease on theses roller shafts to see if the noise go away.
Frigidaire dryer model gleq2152ee0 wont start
Do you see power to the unit? Are there flashing lights or audible beeps? Any error codes or unusual sounds?
Aug 15, 2012 | Frigidaire Dryers
Loud squeeky noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 22, 2011 | Dryers
How to replace a fuse in frigidare model gleq2152ee0
you will need to remove the lid,the the control panel then the front panel needs be removed then the drum need to come out depending on what fuse you are replacing. to remove the belt take off the small access panel on the rear and take the belt off the pulley.
Feb 24, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Squeeky noise in the back of dryer when running?
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes noise when i put clothes in. rubbing squeeky noise
Hello there
the dryer drum rests on rollers that keep it aglinged and straight
if one of these rollers start to wear out this will make the dryer drum misalign which in turn will make the dryer squeel also if the belt is starting to wear this will make it make noises too so i would suggest first opening up the back ofthe dryer and looking at the rollers and seeing if their is any wear from the belt or the rollers and if they are in need of replace ment replace the worn out part ok
Best regards richard
Nov 25, 2009 | GE DBSR453EBWW Electric Dryer
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
176 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
