Question about Xerox Office Equipment & Supplies
Cleaning EXROGRAPHIC MODULE
XEROX WORKCENTERE PRO 265
Printer gives very light print.I wanted to clean it but I stock.Xerographic module has not pulling sytle cleaning. I used ACCSESS button,entered 1111 and I forgot following precedure. I need help
  • 2072 Answers
SOURCE: Xerox 265 toning problem
The charge assembly is part of the module. It is called the Xerographic module.Ther should be a small orange knob sticking out of the module that you can pull out and in that would clean the charge and possibly help. But replacing it would resolve your issue, I am 99 percent certain. The only other issue would be the developer housing, but if that were the problem the machine should fault out and just not run at all.I honestly am not sure of the number, familarity makes you not pay attention to some things. Those are customer replacable. Look up a place on google called The Parts Drop. Get the number and call, ask for Britt, he will help you with what you need. If you have a maintenance contract, Xerox will provide the xero module free of charge.
Its in a pretty big box. about 2 by 3 feet size.
You take the old one out by moving an orange lever sliding the old one out and putting the new one in, there is also a waste bottle on the left side of the machine you pop in and out.
Posted on Jul 20, 2008
SOURCE: xerox pe220 cannot copy
i have the same problem too with my pe220. fortunately, i just purchased a new one which i planned to give to it to a relative, and I was able to figure out that the cause of the "function impossible" displayed.
the problem just occured this morning and I have tried downloading and updating the firmware too, clearing the memories, etc but cannot get the copier to work (can't print thru the pc also).
i then borrowed the new toner cartridge of the new pe220 and installed on my old one and i was able to print and copy again. the problem then is due to the chip memory.
the problem now is how to reset the serial eeprom chip in order to reuse the toner cartridge again.
hope this helps.
Posted on Mar 10, 2009
  • 13 Answers
SOURCE: Paper jams no matter what stock I use; Lexmark e232
Slipping paper feed rollers is probably causing the jamming. Remove the paper tray and tip the machine back so that you can access the feed rollers from underneath. A good technique to isolate this problem is to remove the rubber feed tires, turn them inside-out and refit them. If it now works OK you need to get new feed rollers.
Posted on Jun 04, 2009
  • 64 Answers
SOURCE: xerox 7232 workcentere cannot send emails
Judging from what you've said, I would say this is a setting on the printer. You need to make sure you have the outgoing address correct. Basically go into your printer settings with your E-mail server IP's.
Posted on Jul 17, 2009
SOURCE: blinking amber light will feed labels but doesn't print on them
I have had the same problem and just got my printer working. I moved the peel lever to the lower postion and the printer now works without any problem. The user guide says to postion the lever to the up position (inactive) but that caused the amber blinking lights (not recognizing the label properly)when loading labels. Hope this helps
Posted on Aug 11, 2009
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Workcentre Pro 245 shows an "Internal Power Supply Failure". We just got the machine and it tested OK. We moved it carefully and tested it again OK. But an hour later, it showed this error...
There are 4 solutions to try and they don't fit in their entirety so I included links to each one. Please be sure to read the instructions entirely AND ensure you need to perform each one.
1. Power machine on and off http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4322)
2. Clean the Charge Scorotron and the Transfer Corotron: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4186)
3. Perform a Software Reset at the Printer: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(5315)
4. Replace the Xerographic Module and Transfer Unit: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(3362)
If none of those fail to resolve it call for service.
Hope it helps!
Mar 08, 2011 | Xerox Office Equipment & Supplies
Loud clicking from the manual paper feed? very loud..? xerox workcentere pro 16fx
When printing from the computer, Clicking starts from the printer before printing starts.
Aug 11, 2010 | Xerox WorkCentre XD120F Laser Printer
Xerox copy center C35 - Replace Xerographic module
You can try this.
Press the access button, You will see a button called Enablement Code, then enter this number. *33886714351 .
Make sure you entter the * first, that is the button bottom left on the keypad.
That should allow you 5000 more pages. But it can only be done once. May or may not work on that product. But thats all I know.
Feb 23, 2010 | Xerox Office Equipment & Supplies
Xerox 7232 workcentere cannot send emails
Jul 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Posted the original problem as Blurry Copies for the Xerox WorkCentre X2424. Did what was suggested which was to clean the encoder with alcohol which is located in the drive/drum motor. Now the unit is...
Have u tried the any of the following?
Unlatch Then Relatch the Transfer Unit Below the Xerographic Module
Remove Paper and Other Obstructions From the Paper Path
Use Paper or Other Stock From a Fresh, Unopened ****
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Jul 20, 2008 | Office Equipment & Supplies
Model Number
answered on the other note but, WIth a 265 the problem you have is coming from the xerographic module. Replacing that will help your issue. Charge assembly is going bad and getting hot the longer it runs.
You will start off fine, get some streaky deletions and copy after copy it wil get worse.
Xero Mod will fix it.
Jul 16, 2008 | Office Equipment & Supplies
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
