Question about Toshiba Televison & Video
You recommended that I change my lamp for the reason why I don't have a picture. My model# is tw40f80. does one lamp light up the 3 different color tube's?
  • 261 Answers
Ok I'm guessing you've never replaced teh lamp before, and yes you could replace it and see if it solves the issue... The tv only has one lamp so yes, only one lamp lights up the 3 different color tubes
Posted on Jul 02, 2009
Yesterday, our 61 inch panasonic projection tv showed pink colors on the lighter colors in the picture. This morning it has two large black stripes across the picture. What could this be? We changed the...
You may have not reset the lamp counter after replacing the physical lamp. To do this 1. Press the “POWER” button so that the projector projects the picture on the wall (projection screen)
2. Press the “MENU” button to show the “MAIN MENU”
Use buttons “F” or “G” and select “OPTION”
3. Confirm this by pressing “ENTER” so that “OPTION” is shown
Using buttons “5 / 6”, select “LAMP RUNTIME” (lamp operation counter)
4. Select and press the “ENTER” button for at least 3 seconds
5. The “LAMP RUNTIME” (lamp operation counter) will change to “TIME RESET[POWER OFF]”
6. Turn the device off by pressing “POWER” and unplug the power cord
Sep 09, 2010 | Panasonic Televison & Video
Sony 53" rear projection tv picture comes on scrambled and small with the stand by light blinking then the lamps go out. Whenever the channel is changed stand by light blinks again lamps come on for a few...
There are 2 types of Sony rear projection TVs, one that has 3 picture tubes inside and other has one lamp to produce light.
Model number is important to identify what TV do you have so let me know exact model number written at back of TV to find problem reason and suggest its solution.
Thanks.
Nov 30, 2009 | Sony DAV-C770 System
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
I have sound but no picture?
Have you replaced the lamp before? If not then it's most probable you need to replace it, also listen closely to see if you notice any strange noises like a clicking, humming, whirling or whinning sounds... if you don't hear any of those noises, i recommend you replace the lamp first, but if you have those noises and need free troubleshooting bc it could either be a color wheel or a ballast go to discountdashmerchantdotcom the troubleshoot is free
Jul 01, 2009 | Toshiba TW40F80 40" Rear Projection...
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Toshiba tw40f80, replaced both convergence ic's, power light still blinks
Solder yoke plug and vertical IC connections.....try again.
Let me know.....T.
BTW....Tosh recommends STK-392-110's replace with -110T's
Toshiba OEM.....then there is no question about resistor value
change......
Aug 03, 2008 | Toshiba TW40F80 40" Rear Projection...
Tw40f80 toshiba
YOU SHOULD CALL YOUR THE TOSHIBA COMPANY FOR THEM TO FIX IT.
Jan 16, 2008 | Toshiba TW40F80 40" Rear Projection...
Mitsubishi WS-65857 RPTV: Picture turns Red and Blue
i am having the same problem with my ws-65857. Did you get yours resolved?
Glenn
Oct 06, 2007 | Mitsubishi WS-65857 65" Rear Projection...
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
