Question about Vacuums
Kenmore 39522 vacuum beater bar keeps rotating after unit is shut off. Even unplugged it to move to another room and when I plugged it back in, the bar rotated a few more times! Has a definite clicking sound when this happens. Purchased in January 2008.
  • 75 Answers
The berings or something inside might be going bad.
Posted on Jul 02, 2009
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
There seems to be a short between the canister and the extension wand hookup. Right at the plug between located at the front of the canister and where the extension wand plugs in. When you rotate the...
Well, Anthony, considering as how I have no idea of what brand, make, model or color your vac is, I can't make much of a guess as to why it doesn't work. We'd need more info if you want to log back on at a later date, such as brand, model, maybe even a picture of the unit so we could see just where your problem might be.
Oct 22, 2013 | Vacuums
I was cleaning the hair from the beater bar, and it popped out with the belt still attached...have tired to put it back in , but the beater bar will not rotate when the vacuum is turned on
when you put it back make sure that the ends of the bar fits exactly in the ends o the box and has to roll smoothly even when you rotate it with your hand when you try this has to be disconnected
Jun 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar not rotating
Remove the screws from the bottom of the power head.
Oct 09, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Change belt on a eureka
With the vacuum unplugged, turn the machine beater side uo. On the plate that surrounds the beater bar, look for release tabs to open the plate. Flip them and set the plate to the side. The beater bar rides in sockets. Remove the bar, install the new belt around the motor shaft, then work the beater back into the sockets. Replace the plate. Test your work by rotating the beater bar by hand, making sure that it is reinstalled correctly.
Best Regards, --WoobieDog--
Jul 10, 2009 | Eureka Vacuums
The agitator on my kenmore progressive vacuum won't keep going. It keeps stopping while vacuuming.
This sounds like the belt that drives the beater bar on the vacuum. The beater bar bearings and brushes could be plugged with debris and/or the belt is simply worn out and needs to be replaced. Unplug the vacuum, turn it over and look for clogging.
If you can't see any, then you may need to remove the bottom plate of the vacuum and clean out and/or replace the drive belt and clean the area. These belts and other components are usually available at Sears Hardware or main stores. Make sure you get the correct belt for your vacuum.
If the beater bar brushes are substantially worn, it would also be a good idea to replace the beater bar as well. These parts wear out after a few years. Try to work on the unit in a location that is well ventilated and the debris doesn't make a mess inside your house.
Apr 27, 2009 | Vacuums
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
