Question about Bissell 1715-G Spotlifter Bagless Handheld Vacuum
Bissell 1715-g spotlifter
I purchased one of these at a thrift store but have no directions. can i find them somewhere online.
thank you , charlene
  • 1,673 Answers
Re: bissell 1715-g spotlifter
Go to, put in your model number and if available, you can download it from there.
Posted on Feb 06, 2008
0 characters
3 Points
Need Bissel 1715 wiring schematic. Charging circuit has burnt resistor. Need to know resistor details.
Can not believe NO ONE could answer this.
The R1 resistor basically drops the 9V to around 5V for charging the battery pack. The resistor is a 10 ohm , 2 watt resistor. The other resistor is 220 ohm. This only limits the current to the LED.
The 10 ohm resistor burnt because the battery pack was left to sit too long without use and charging. So the cells shorted causing excessive current through the resistor when you attempted to charge the batteries.
After replacing the resistor, you will need to replace the battery pack before charging. Otherwise, you'll just burn the resistor again.
Sep 27, 2010 | Bissell 1715-G Spotlifter Bagless Handheld...
I lost the instructions to use my Bissell Spotlifter. Can you help?
BISSELL User's Guides can be downloaded at
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Dec 19, 2009 | Bissell 1715-G Spotlifter Bagless Handheld...
Bissell 1715-g spotlifter and search model # 1715. It gives you the option to see the owner's manual in PDF.
Dec 12, 2008 | Bissell 1715-G Spotlifter Bagless Handheld...
Need directions for use
This is a similar model to the one you have. Would give you some indication of how to use.
Nov 23, 2007 | Bissell 1715-G Spotlifter Bagless Handheld...
Bissell 1715-G Spotlifter Bagless Handheld Vacuum Logo
103 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
