Question about Sony CDX-F7700 CD Player
Faceplate not working
A few weeks ago I was changing the radio station on my faceplate and it began to freeze up. It would not let me switch between the stations. Then it would not let me adjust the volume. So I turned it off hoping it would just reset but it would not turn back on. I tried the reset button but that didn't do anything either. So right now I cannot turn the stereo on at all. The faceplate still has some scrolling text and the clock and displays Sony so it must have power. If you pop a CD in it will play but you cannot adjust the song, volume etc. anything with the faceplate. I'm not sure if I should try replacing the faceplate or if it something more than that.
  • Burnden babe Dec 22, 2007
    I am having the exact same problem. The writing is scrolloing on the display but none of the buttons are working. I am currently listening to CD's at the same volume and to eject I have to remove the face plate and press the re set button.
I had exactly the same problem and I solved it replacing the faceplate.
Rafael Luciano, 2010
Posted on Jul 01, 2010
  • 26 Answers
Try disconnecting the unit completely.
Posted on Nov 09, 2007
Can't change radio stations or skip cd trac
The Buttons on the Selector Switch are dirty or
Your Radio is needs to be replaced...
I would start with Testing the Circuit Board and wiggling the Faceplate but chances are you are going to need to replace the radio
Apr 08, 2013 | 2001 Nissan Maxima
Turns on but won't turn off. All of the buttons on the faceplate do not work but it is lit up. Can only listen to the one station when I turn it on. Will play CDs but no way of changing the tracks. To...
It sounds to me like you may have a bad volume control switch. Unless you are good at unsoldering and soldering, I would suggest you have it repaired by a professional. Either that or see if you can find a replacement face at a pawnshop or something like that.
Sep 08, 2011 | Panasonic CQ-DF402U CD Player
Kdc-x993 - power to head, but no display when face is installed. the cd eject button is blinking but when i install the face, the display will not come up.
you dont have power to the ignition wire on the radio(red wire) the yellow wire should have constant power(12 volt) check your radio fuse in the fuse block on the car or on the red wire itself
Jan 23, 2010 | Kenwood Car Audio & Video
Jensen MP5720 radio/faceplate connector is broken or missing spring
I was always afraid this might happen to me so I never removed the faceplate from the radio. This strategy worked fine for two years until two weeks ago. I didn't lock my car because of the freezing rain and somebody stole my faceplate and remote. Anyway I ordered a replacement radio from Amazon last week so I don't have rewire a new one. The replacement cost me $100. I don't really need the rest of the radio so make an offer, my email is cs1713@sbcglobal.net
Regards, Chas
Sep 18, 2008 | Jensen MP5720 CD Player
Faceplate not working - will remote solve problem?
PLEASE FIRST CHECK THE FACEPLATE TO HEAD UNIT CONNECTIONS (WHERE THE FACEPLATE CONTACTS THE HEAD UNIT ).
THEN IF U ARE SATISFIED ,REPLACE THE ENTIRE RECEIVER.
May 10, 2008 | Pioneer DEH-P4700MP CD/MP3/WMA/WAV...
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
Wont change channels
First, try resetting the faceplate CPU by shorting the proper pins on the faceplate to radio connector on the back of the faceplate with a piece of wire... They are marked on the connector, if this fixes it for you, enjoy!
If that doesn't work, then remove the back cover of the faceplate and check the faceplate connector itself for bad solder joints. As a matter of fact, check the entire radio for bad solder joints before looking any further.
I bought one of these radios a short time ago; Everything worked except for LSB.
I was told by the radio shop I bought it from that I'd have to wait until June to get it fixed, so I opened it up myself to see if it was something easy to find/fix, since I felt that if it was anything major it wouldn't be able to get AM or USB either.
In my case, I found bad solder joints on the faceplate connectors and a bad solder joint on one of transistors attached to the heatsink.
Once I fixed those two things, it's been a great little radio.
Be sure to reset the faeplate after resoldering and assembling, to clear any errors from the CPU.
Apr 05, 2008 | Midland 79-290 120-Channels Base CB Radio
Bad face plate!
It may be the flexible connector link connecting to the drop down faceplate.
Aug 14, 2007 | Dual XDMR-7700 CD Player
Sony CDX-F7700 CD Player Logo
608 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
