Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Lost manual lost owners manual for my hoover steamvac model F6213-900. can I see one online please?
lancer721
  • 229 Answers
SOURCE: Hoover SteamVac F7222-900 steamvac Brushes do
There has to be a belt to those brushes that is bound up or broken. Find the belt to repair.
Posted on Dec 01, 2008
  • 107 Answers
SOURCE: NO DIRECTIONS FOR HOW TO ATTACH AND USE STAIR TOOL FOR MY HOOVER
Here is the link to Hoover's manuals. I could not locate a model F5900-900 But i believe it is F5914-900. Please verify before downloading manual by checking the serial number stick for a model. Its silver and should be on the back or bottom.
Posted on Dec 09, 2008
  • 3 Answers
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
ginko
  • 19396 Answers
SOURCE: Need a Manual
Check the links below:
Online User Manual and Guide for Hoover F6020-900
Do n ot forget to leave rating.
Thanks.
Posted on May 30, 2009
We need a user manual/directions for a f5905-900 hover steam vac clean surge.
Hi There,
Unfortunately the Hoover F5905-900 is a little outdated, and Hoover doesn't have that model on their site. They do however have the Hoover F5906-900 instruction manual which I linked below. This model is identical to yours, and will explain all that you need to know.
If it's parts that you are looking for, here's a link to the parts for the Hoover SteamVac on our website:
Hoover SteamVac Parts & Accessories
If it's something else that you need help with, please don't hesitate to add a comment on this page with your question/concern and I'd be more then happy to help you out.
Here's the link to the owners manual:
Hoover SteamVac F5900 Series Owners Manual
If this answered your question, please be sure to rate the repair helpful, or leave feedback for me, this is greatly appreciated by the Fixya community. Thanks again!
Chris Jones
GoVacuum.com
Jun 09, 2010 | Hoover F5906-900 Upright Steam Vacuum
Lost manual for hoover steam vac
You can find that manual on hoovers website (hoover.com) it is under customer service/parts.
Best of Luck
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Need a Manual
Thanks.
May 30, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
I need yo find out hoe to use the upholstry attachment. Ilost my
I'm not quite sure where the attachment plugs in but, I did find an owner's manual for this Hoover online.
http://www.hoover.com/pdfs/manuals/F5918900.pdf
I hope that helps. Good luck!
May 25, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Need manual
To all the users looking for this manual.
Regards.
Jun 29, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover steam vac spin scrub
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
44 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
