Question about Norelco 3405 LC Electric Shaver
Need new replacement blades part #, for norelco 3405 LC shaver
    Guru:
  • 174 Answers
Norelco 3405LC electric shaver replacement heads is Philips Norelco HQ56 replacement heads.
Posted on Nov 15, 2012
brector3
  • 1624 Answers
SOURCE: Where can I buy replacement
You will find replacements at shaveroutlet.com. See links below
http://shaveroutlet.com/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
or
http://shaveroutlet.com/parks-pp04-replacement-heads-fits-norelco-hq4-p-632.html
Posted on Sep 20, 2010
brector3
  • 1624 Answers
SOURCE: How to lubricate Norelco 3405 shaver?
The sewing machine oil should work fine.
This model has 4 screws on the back. You must push up the trimmer to see two of those but the other two are in plain view. Remove screws with a flat jewelers screwdriver or you can purchase a special removal tool from shaveroutlet.com here:
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Once the back cover is removed, you will be able to see the motor. It is attached to the gear housing by two metal clips. Remove the clips and you can lift the motor out. Apply a couple of drops of your oil to the pinion gear on the 'front' of the moto and a drop to the small indentation on the back of the motor.
If you still have noise. you will need to lubricate the gears. Temove the gear housing by removing the 2 screws that are on either side of the motor. The gear housing will then come off. The front and back of the housing are held together by plastic snaps on the three corners. Gently pry them apart to seperate and reveal the gears inside. Lift the gears out and apply a light form of grease to where the gears fit onto the back of the gear housing. Vaseline should work well if you have nothing else.
Reassemble in reverse order and it should run very quiet when you're done
Posted on Jan 26, 2010
EwingElect
  • 276 Answers
SOURCE: Norelco 5825XL Replacement Blades
HQ5 is not compatible with HQ55. I've checked the Service Manual and HQ5 is the correct part. It's got to do with the driving mechanism for the head.
Posted on May 18, 2010
  • 8 Answers
SOURCE: cannot put new HQ 5 Norelco replacement shaving heads in shaver
Any way, the HQ5 head must fit in the 3 heads but will leave 2 of your HQ 5 heads free. But still the game can go on, wel u have to adjust some things in life.
Posted on Mar 20, 2009
brector3
  • 1624 Answers
SOURCE: The head holder of my Norelco Philips HQ6707 shaver is cracked
You will find a replaceent for model HQ6707 at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-6700-series-cool-skin-head-holder-p-310.html
Posted on Jul 23, 2010
Norelco hq8 compatiable with hq9
Norelco HQ8 incompatiable with HQ9.
Your question about Norelco 3405lc electric shaver, Philips norelco HQ56 replacement heads fit on Norelco 3405 LC blades replacement parts.
Norelco HQ56 Replacement Heads
Jun 26, 2014 | Norelco 3405 LC Electric Shaver
Tip
I accidentally ran my 3405 LC on 220V ! What can I try to fix it?
Most likely R3 (470 ohm) and R4 (430 ohm) are burned and need to be replaced, these are both 1/4 watt resistors. Probably good to check the diodes for a dead short, but these resistors most likely opened first. Hope this helps, Good luck!
on May 25, 2012 | Norelco 3405 LC Electric Shaver
Replacement blades
You will find blades for model 3405LC at shaveroutlet.com using the link below
http://shaveroutlet.com/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Jun 23, 2014 | Norelco 3405 LC Electric Shaver
Blades fo Philips razor HQ6843
In the UK, philips norelco HQ56 replacement heads for electric shaver philips razor HQ6843 blades replacement parts.
Mar 23, 2013 | Norelco 3405 LC Electric Shaver
NEW ELECTRIC CORD FOR NORELCO 3405LC?
norelco 74-C20 adapter charging cord for electric shaver norelco 3405lc power cord replacement parts.
Mar 03, 2013 | Norelco 3405 LC Electric Shaver
Are Norelco HQ9 Blades interchangeable with HQ55 blades?
philips norelco HQ56 replacement heads compatiable noelco HQ55 blades.
philips norelco HQ56 for norelco 100db, 110db, 1323, 2005c, 200sc, 300sx, 3405lc, 3601x, 3604x, 3605x, 3801xl, 3805xl, 3865xl, 400dx, 410db, 4401lc, 4402lc, 4403lc, 4404lc, 4406lc, 4413lc, 4414lc, 4417lc, 4601x, 4602x, 4603x, 4604x, 4605x, 4606x, 4607x, 4608x, 4625,x 4805xl, 4807xl, 4816xl, 4816xld, 4817xl, 4817xld, 4821xl, 4825xl, 4825xld, 482xl, 4845xl, 484xl, 4852xl, 4853xl, 4861xl, 4865xl, 486xl, 4885xl, 500rl, 501rl, 505rl, 5426lc, 5625x, 5812xl, 600rx, 605rx, 6423lc, 6424lc, 6613x, 6614x, 6615x, 6616x, 6617x, 6618x, 665rx, 6843xl, 6844xl, 6853xl, 6854xl, 6856l, 6856xl, 6863xl, 6940lc, 6945xl, 700rl, 705rl, 710rl, 715rl, 720rl, 725rl, 750rl, 800rx, 805rx, 815rx, 825rx, 835rx, 850rx, 875rx, 885rx, 885rxac, 895rx, 900rx, 905rx, 915rx, 935rx, 945rx, 950rx, 955rx, 965rx, 968rx, 975rx, 985rx, hp1318, hp1319, hp1327, hp1327d, hp1328, hp1328e, hp1328s, hp1337, hp1337c, hp1601, hp1602, hp1604, hp1605, hp1606 and hp1608.
Feb 02, 2013 | Norelco 3405 LC Electric Shaver
Where can I find replacemet blades fr a norelco 3405LC electric shaer?
philips norelco HQ56 replacement heads for electric shaver norelco 3405lc cutter blades replacement parts.
Feb 12, 2012 | Norelco 3405 LC Electric Shaver
Norelco 3405 LC Electric Shaver Logo
142 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
