Jenn-Air JMV8208A  Microwave Oven Logo
Posted on Jul 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help in installing the back bracket on the wall for my jmv8208bas
Anonymous
Level 3:
  • Master 999 Answers
  • Posted on Jul 02, 2009
Anonymous
Master
Level 3:
Answers
999
Questions
Helped
311104
Points
2740
If you do not have the original template you can hold the back plat up on the wall and mark the screw holes. Try to get at least 3 on studs. It will have to be down from the cabinet a little to allow for the micro to swing up into place.
Eric
Jmv8208bas manual
http://kitchen.manualsonline.com/manuals/mfg/jennair/jmv8208bas.html?idProd=1511577 Free Jenn Air JMV8208BAS Microwave Oven User Manual ManualsOnline com
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
3helpful
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
1helpful
HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
2helpful
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
Need installation instructions for the spacemaker GE microwave oven model JVM164owj01
Here is the link to the installation manual. Cut and paste on the address bar of your browser. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF It is possible to do it by yourself, but its a royal pain in the a**, so have someone available to help you lift it into place and hold it while you get the screws into the cabinet above. You could use sheet rock anchors to put the mounting bracket on the back wall, but I would really suggest getting the mounting screw into wall studs instead, even if you have to drill a hole or two through the mounting bracket.
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
1helpful
Sounds easy...but
Installing one of these between two cabinets and supported by the one above it is a pain ..but even worse if you don't have the installation directions. If you are relatively handy and have some carpenntry experience, I'll walk you thru the way I install them. First off, I assume you are installing this above a stove and betwwen two wall cabinets.. You need to do a little preparation work first. locate the wall mount bracket and you should have a packet of hardware ( primarily two long screws that will be used to support the front of the micro from the cabinet above) If you have all this.. you'll need to determine if you are going to vent the micro back into the room or plan to vent it outside. The simplest is to vent it back into the rook thru a charcoal filter but if you are going tovent it outside, you have two choices.. one is to vent it up thru the cabinet and outside via ductwork that you buy..if the microwave oven is being attached to an outside wall then it is easiest to vent it straight out the back ( i say this because you have to orient the blower in teh configuration that you are planning to use) Let's assume you will be venting this back into the room ( that's the easiest ) and move on.. The wall mount bracket supports the back bottom of the microwave oven when you secure it and the two long screws will be used to bring the front of the micro up against the bottom of the cabinet above it... I normally locate the wall studs and then buy and fit a 1/2 inch piece of plywood onto the wall where the micro will be mounted. The microwave will project out 1/2 inch further as a result of this plywood panel but.. you can use lots of drwall screws to the secure the plywood to the wall studs and then you can mount the wall bracket onto this plywood without having to worry about where the studs are and if it will support the microwaves weight. Mount the bracket onto this plywood piece. I will use drwall screws and add flat washers to them to provide additional support. Once that bracket is installed, you will need to figure out how you are going to provide power to the microwave. If you are replacing an existing oven then you will probably have a power fees inside the cabinet =situated above the microwave oven. If not, then you will need to provide a power feed for this. In the old days, most of these appliances were hard wired into junction boxes but nowadays, most appliances are treated as removable and all you will need is an outlet box in the cabinet above. I suggest you bore a hole large enough for the power cord plug to fit thru the bottom of the cabinet so that you can plug it in. The next part is the hardest to accomplish.. If you look at the top of the microwave oven, you should see two holes near thhe front and on top. Those two holes have floating captive nuts inside them that the long screws ( included in your hardware kit) will be used to snug the front of the micro up against the bottom of the cabinet above it.. The trick is to measure from the back wall out to where these holes need to be drilled in the cabinet above so that they line up. You can drill bigger holes than you need and use oversize washers if necessary. If this sounds complicated ..it IS.. i have put many of these in and unless you are actually doing one, youhave no idea how involved this can be.. even worse with ducting to the outside.... I hope this gives you some tricks on how to install.. And um.. if you do get this all together, you will need some help actually putting it in place.. You'll need to catch the back of the microwave onto the tabs of the wall bracket and then feed the wire thru the cabinet while you lift the entire thing up to start the screws from the cabinet down onto the top of the microwave. I'm a big guy and have done these myself but it is not easy.. Hope this helps you.. Lastly, here is a link to the GE website where you can download the user manual and search their FAQ for install details ( in retrospect, I just should have given you that info).. http://www.geappliances.com/service_and_support/literature/
Hope this helps you...
Top Jenn-Air Microwave Ovens Experts
rajanshyam
Level 1 Expert
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
