Question about Sharp AR C250A Color Copier
Registration problem konina 7065
How can i adjust registration in konica 7065
  • 145 Answers
Timing adjustment, perform the following.
1. Access the 36 mode (power the machine ON while holding down on the 4 and 7 keys.
2. Press [2] Image adjustment.
3. Press [3] Timing adjustment
4. Press [3] Lead edge timing adjustment
5. Press [Copy Screen]
6. Load 11x17 paper into tray 1, make a copy of the pyramid chart, and check the output.
Standard value: 3mm max.
7. If the lead edge original amount is different to the standard value, press the C button while pressing the P button.
8. Enter a value from the numeric keys on the screen, and press (SET) key.
Setting range: 0 (small) to 99 (large)
1 Step = 0.064mm.
9. Repeat steps 5 to 8 until the lead edge original erasure amount becomes the standard value.
10. Press the [PREVIOUS SCREEN) key to return to the Timing Adjustment Menu Screen.
11. Power the machine OFF/ON to exit the 36 mode.
PLEASE NOT THIS IS A LEADEDGE ADJUSTMENT.THE REIGIST ADJUST IS THE SAME STEPS JUST CHOOSE REGISTRATION OPTION ,AND MAKE SURE TO FOLOW PROPER DIRECTION.
Posted on Jul 13, 2009
MY MACHINE KONICA MINOLTA SHOWS MACHINE STATUS P9 AND P21. WHAT CAN I DO?
Registration error. run registration adjustment in service mode. Recommend a tech do that
Apr 13, 2017 | Konica Minolta Office Equipment & Supplies
Trouble code c2551 on konina minolta bizhub c454e
c2551 come when Cyan low toner in Cyan Developing Unit.
Try to reset by opening and closing front door.
and check toner supply-hopper
if not still ok then replace Cyan Developing Unit.
Nov 30, 2016 | Konica Minolta bizhub Office Equipment &...
F52-1 error code on konica 7055
Check all fans, and filters might need a good cleaning around them.
May 27, 2014 | Konica Minolta Copier Toner 7055/7065...
I have a Konica 7065 I need to replace the developer in it and then I will need to reset the counter
to reset counter turn off main switch hold down 2and 5 turn on release 2 and 5 a different screen will show select 3 PM count/ cycle, set off and is done
Jun 16, 2010 | Konica Minolta Office Equipment & Supplies
After changing developer on konica 7065 what is the st up procudre ?
You must perform ATDC sensor gain procedureF8 and AIDC sensor F5 perform.
Dec 28, 2009 | Konica Minolta Office Equipment & Supplies
Registration
you copy registration, w/out RADF? Or RADF registration adjustment?
Jul 02, 2009 | Sharp AR C250A Color Copier
Registation problem
Exists adjustment VWVstand up front edge. If you have servise documentation try to correct the registration begin copyings. I it is necessary to see the picture, as beside you cut, blanching band or begins the scene not first картнки but later. Send the picture scaning. Thank you
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Sharp AR C250A Color Copier Logo
176 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
