Question about Sharp AR C250A Color Copier
Registration how can i adjust registration in konica 7065
    Sergeant:
  • 210 Answers
You copy registration, w/out RADF? Or RADF registration adjustment?
Posted on Aug 10, 2009
MY MACHINE KONICA MINOLTA SHOWS MACHINE STATUS P9 AND P21. WHAT CAN I DO?
Registration error. run registration adjustment in service mode. Recommend a tech do that
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 13, 2017 | Konica Minolta Office Equipment & Supplies
F52-1 error code on konica 7055
Check all fans, and filters might need a good cleaning around them.
May 27, 2014 | Konica Minolta Copier Toner 7055/7065...
I have a Konica 7065 I need to replace the developer in it and then I will need to reset the counter
to reset counter turn off main switch hold down 2and 5 turn on release 2 and 5 a different screen will show select 3 PM count/ cycle, set off and is done
Jun 16, 2010 | Konica Minolta Office Equipment & Supplies
After changing developer on konica 7065 what is the st up procudre ?
You must perform ATDC sensor gain procedureF8 and AIDC sensor F5 perform.
Dec 28, 2009 | Konica Minolta Office Equipment & Supplies
Registration problem konina 7065
timing adjustment, perform the following.
1. Access the 36 mode (power the machine ON while holding down on the 4 and 7 keys.
2. Press [2] Image adjustment.
3. Press [3] Timing adjustment
4. Press [3] Lead edge timing adjustment
5. Press [Copy Screen]
6. Load 11x17 paper into tray 1, make a copy of the pyramid chart, and check the output.
Standard value: 3mm max.
7. If the lead edge original amount is different to the standard value, press the C button while pressing the P button.
8. Enter a value from the numeric keys on the screen, and press (SET) key.
Setting range: 0 (small) to 99 (large)
1 Step = 0.064mm.
9. Repeat steps 5 to 8 until the lead edge original erasure amount becomes the standard value.
10. Press the [PREVIOUS SCREEN) key to return to the Timing Adjustment Menu Screen.
11. Power the machine OFF/ON to exit the 36 mode.
PLEASE NOT THIS IS A LEADEDGE ADJUSTMENT.THE REIGIST ADJUST IS THE SAME STEPS JUST CHOOSE REGISTRATION OPTION ,AND MAKE SURE TO FOLOW PROPER DIRECTION.
Jul 02, 2009 | Sharp AR C250A Color Copier
Registation problem
Exists adjustment VWVstand up front edge. If you have servise documentation try to correct the registration begin copyings. I it is necessary to see the picture, as beside you cut, blanching band or begins the scene not first картнки but later. Send the picture scaning. Thank you
I have a Konica 7065 and a dont' have the ECM password how can i find it.... Ever Vega
you can accessf the ecm but you have to know the old password to get all the information. if you don;t know you will lose all the info. press p and enter 9272 and it is under 25 mode. the password 12345678.
Jun 28, 2009 | Konica Minolta Riva Zoom 70 35mm Point and...
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Sharp AR C250A Color Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
