Question about Sharp AL-1641CS Laser Digital Copier
Sharp AL 1641 CS L4 Code
I know this a scanner locked code. But I don't know how to fix it.
  • lawriderman Dec 09, 2008
    Sharp copier SF-2214. Replaced toner and get L-4 problem code. Paper does not feed through. Gives paper jam and toner signal.
Under the glass copier/scanner bed, in the area where the copies eject, there is a clear plastic dial that can be turned either to the "lock" or "unlock" position. Turn this clear plastic dial. Be sure to lock the unit when transporting it.
Posted on Feb 04, 2009
Preciso dos drivers de scanner desta sharp al-1641cs
Posted on Nov 05, 2008
Check the lock under the scanner
Posted on Dec 18, 2007
  • Sharp Master
  • 1,113 Answers
Code L4-16
That code is for a motor lock in the fuser area. More than likely the part will have to be swapped out for a new one by a Sharp technician.
If you're in the Houston area we'd be glad to get you fixed up.
Skelton Business Equipment Houston Copiers
Aug 05, 2014 | Sharp Mx-C402sc mx-C402sc
Can you help: when you turn on the copier AL 1641 CS performs its start-up, pressing enter to copy the scanner remains in the home position of left side
Sounds like the scanner latch is in the locked or latched position. You can hit them easily removing the copier. Look under the area you remove your copies. On the bottom of the scanner, there is a latch lever. Flip it to the unlocked position.
Feb 03, 2011 | Sharp AL-1641CS Laser Digital Copier
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Model 7100 starts up and getting a reading of L4
code L4: sub code 01: Main motor Lock detection sub code02: Drum motor lock you need to call for service
Dec 27, 2010 | Sharp AL-1000 Copier
My unit is Flashing H Then 4. Sharp AL-1641 CS. What is wrong
When this machine H 4 flashing
problem: Fuser unite over temperature
Solve: Press C Exposure button again C Exposure button 14 press start key
C exposure c exposure p 14 press start
Or H4 fixed
Solve: Replace Heater lamp or heater fuse
Dec 16, 2009 | Sharp AL-1641CS All-In-One Laser Printer
Sharps AL 1530CS flashing L service code and shuts down
You didn't mention the number or code or L code.
If its L1-00 its just only the scanner, it means the scanner is locked.
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Feb 23, 2009 | Sharp AL-1530CS All-In-One Laser Printer
L4 Code
you have to unlock the machine from the bottom part of the scanner there is a littler lever .if the lever is unlocked try with the folowing this take off the glass then clean and lubricate the shaft
where the carriage is back and fork
Nov 09, 2007 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-1641CS Laser Digital Copier Logo
565 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
