Question about IBM 4247 Model V03 Matrix Printer
IBM Printer 4247 in Parallel Mode
We have 2 old IBM 4247 printers.
On the front display, one printer now reads READY PARALLEL
The other printer shows LAN ASCII...
The printer displaying PARALLEL is not printing....
Any way to change from parallel to LAN ?
    Scholar:
  • 111 Answers
They are auto switching units. All you have to do is configure it correctly and send a job, it selects the interface your are printing thru.
If you have any questions or if you are looking for parts for this unit please contact me back.
Thanks
Rory Cardenas
Midrange Repair and Parts
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 29, 2009
Lipi6306 matrix printer not going to offline mode always in online configure 1
step 1 : change the panel cable
step 2 : change the control panel
step 3 : download firmware as follows :
T6306 FIRMWARE DOWNLOADING PROCEDURE
  1. Connect the printer to pc through parallel port.
  2. Press "FF + ^ + CONFIG" at the control panel and power on the printer .
  3. Panel will show "ready to download".
  4. In dos mode type "vdv3000r -pb" and enter .
  5. After completing the firmware loading printer may show NVRAM fault.
  6. Press "CLEAR"and printer will restart to finish.
Mar 02, 2014 | Tally Line Matrix T6050 Printer
How to change from parallel to serial
if your PC has a serial port I'd think the motherboard should have a parallel port header on board. What you'd need to find would then (if my idea is right) just be a parallel port bracket for your computer (to be mounted at the back, in one of the plugin card spaces) which should come with a standardized connector to fit the header on the motherboard. After connection make sure that the parallel port is enabled in your BIOS
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 07, 2014 | IBM 6400 Office Equipment & Supplies
Error badint 0085ddc0
The 'badint' error on the T6100 indicates the printers firmware has for some reason 'crashed', this error should not be seen in normal operation of the printer.
One common cause of "BADINT" messages is the use of an external print server or host computer with incompatible parallel-port settings. If you have an external print server connected to the printer's parallel port there is a setting on the print parallel interface that may need changing, to change parallel interface setting. • Set the printer to Offline. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On) • Press the Mode key: display will show Offline Normal. • Press any Arrow key until display shows Offline Config. • Press the Forms/1 key. • Press any Arrow key until display shows Config Paralel. • Press the CPI/2 key. • Press any Arrow key until display shows Paralel Bi-Dir. • Press the LPI/3 key. • Press any Arrow key until display shows Bi-Dir Off. • Press the Enter key and the interface will be set. • Press the Clear key. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off) On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Nov 04, 2011 | Tally Line Matrix T6100 Printer
Error lost cpu rest
This error on the T6125 may be caused by either a hardware fault with the printer, alternatively the problem may be caused by some sort of external influence on the printer. Passable resolution to the problem include;
Hardware Fault
Locate the main logic board, check the CPU to ensure all pins are soldered correctly on the PCB. Check there is no solder over spill shorting any of the pins.
There may be a fault with the main logic board which may require replacement.
External Influence
1) External Print Server
One of the most common causes for the LOST CPU error is the use of external print servers connected to the Parallel Interface.
These printers are not reliable if connected to external print servers unless the printer parallel interface has been set Uni-Directional. To do this, you need to follow these instructions.
Press any Arrow key until display shows Config Parallel.
Press any Arrow key until display shows Parallel Bi-Dir.
Electrical Interference
Check the area around the printer to ensure there is no external electrical interference eg Electric Motors, High Voltage Cables in near vicinity of the printer.
Feb 21, 2011 | Tally T6215 Matrix Printer
Table mismatch error ibm 6400
Hi
Occasionally you willneed to reload the flash memory in the printer. To do this you will need a PCor laptop, a parallel or serial cable, and the correct flash code file. Thepart number for the flash code file can be found on the configuration printout.If the printer is not functioning and a current copy of the configurationprintout is unavailable you will need to gather some information to enable usto get the correct code for you.
In order to determine the correct flash code for the printer you will need toknow if the printer has any additional interfaces, the part number of thesecurity pal, the model of the printer, the amount of flash memory and draminstalled, and if the customer uses PGL, VGL, or IPDS graphics.
Once you have the correct flash code file you will need to copy it onto thehard drive of the PC you will be using to flash the printer.
Connect your data cable (parallel or serial) from the pc to the printer
On the printer, hold down the Start & Cancel keys while powering on theprinter. Continue to hold both keys down for 5 seconds and then release them.
The default download mode is parallel (Centronics). This is the easiest port toflash the printer through. If you need to change the download port to serial,see the note at the end of this article.
At this point the display should read "Waiting for Program Download".
On the pc, open a Dos window. At the command prompt, change directories to thedirectory in which you stored the flash code file.
At the command prompt type:
filename.exe -pb
where "filename.exe" is the name of the flash code file you areusing.
While the file is being copied into the printers memory the display will showyou the load process and status.
Do NOT interrupt the load process as this can damage the memory and controllerboard.
When the program has finished loading the printer will reset itself.
If after resetting itself the printer displays a Par error, table mismatcherror, or hangs on initialization reload the code again.
Once the code has successfully loaded and the printer has reset itself, poweroff the printer.
Disconnect your cables and reconnect the customers cables.
On certain 475 and 500 lpm models you will need to set the shuttle speed.
On 1400 and 1500 lpm models you will need to set the coil temperature.
On all models you will need to run a test print and adjust the hammer phasing.
NOTE: If you need to flash the printer through the serial port you will needto follow these additional steps.
When you see "Waiting for Program Download" on the LCD press theScroll Up key. The display will now show "Select DownloadPort=Dataproducts".
Press the Scroll Up key to cycle through the available download ports.
When the display shows the download port you would like to use, press the enterkey.
The display should now show "Waiting Download/Port=" and the port youhave selected.
At the Dos prompt type:
MODE COM1:9600,N,8,1,P
filename.exe -pbc1
Continue with the flash download procedure.
Nov 16, 2010 | IBM 6400 Matrix Printer
I have a 4247 printer attached remotely via TCP/IP to my i5 and several times during the day, a user will attempt to print something and the the print job sits in PND status and nothing prints. The printer...
1) what do they do to get the printer to start back up agian
2) if you press and hold the button on the NIC card for 5 sec will the NIC print it's self test?
Rory Cardenas
Alsip IL 60803
3821 W. 127th Place
708-597-4222 X240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 08, 2009 | IBM 4247 A00 Matrix Printer
My printer has a parallel plug and my new docking station...
You can buy a cable that goes on your old printer cable to convert to USB most computer shop will hav these or can get one
Jan 25, 2009 | IBM (250410U) Docking Station for ThinkPad
4247 Printer with a 56 Print Error
47b6dfe.jpg Hi,
There are a number of potential causes for this error. the most likely is a dirty Printhead Home sensor ( see Pic). Try cleaning it with a cotton bud or compressed air.
Does the problem occur during a self test ? ( print at leat 10 pages )
Let me know if this doesn't sort it.
Aido
Dec 07, 2007 | IBM 4247 A00 Matrix Printer
IBM 4247 Model V03 Matrix Printer Logo
359 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
