Question about Sharp AR C250A Color Copier
Registation problem Ihave a problem in konica 7065 about registration my copier is cutting print from starting
    Guru:
  • 389 Answers
Exists adjustment VWVstand up front edge. If you have servise documentation try to correct the registration begin copyings. I it is necessary to see the picture, as beside you cut, blanching band or begins the scene not first картнки but later. Send the picture scaning. Thank you
Posted on Sep 16, 2009
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
I have a bizhub451 is not registration fine
Sir what do you mean registration fine. What print out?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 26, 2015 | Konica Minolta Office Equipment & Supplies
My machine is showing me p-22 what does it mine
Color regist adjust failure
• The color shift amount is greater than the specified
range during main scan direction registration correction.
range during sub scan direction registration correction.
• On the color shift test pattern, the maximum and minimum
deviations detected in the main and sub scan
directions go over the predetermined value.
Dec 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Failure to register in yellow bizhub c6501p
Could be print head, or registration issue with yellow have a tech check it out.
Jan 21, 2014 | Konica Minolta bizhub Office Equipment &...
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
Registration problem konina 7065
timing adjustment, perform the following.
1. Access the 36 mode (power the machine ON while holding down on the 4 and 7 keys.
2. Press [2] Image adjustment.
3. Press [3] Timing adjustment
4. Press [3] Lead edge timing adjustment
5. Press [Copy Screen]
6. Load 11x17 paper into tray 1, make a copy of the pyramid chart, and check the output.
Standard value: 3mm max.
7. If the lead edge original amount is different to the standard value, press the C button while pressing the P button.
8. Enter a value from the numeric keys on the screen, and press (SET) key.
Setting range: 0 (small) to 99 (large)
1 Step = 0.064mm.
9. Repeat steps 5 to 8 until the lead edge original erasure amount becomes the standard value.
10. Press the [PREVIOUS SCREEN) key to return to the Timing Adjustment Menu Screen.
11. Power the machine OFF/ON to exit the 36 mode.
PLEASE NOT THIS IS A LEADEDGE ADJUSTMENT.THE REIGIST ADJUST IS THE SAME STEPS JUST CHOOSE REGISTRATION OPTION ,AND MAKE SURE TO FOLOW PROPER DIRECTION.
Jul 02, 2009 | Sharp AR C250A Color Copier
Registration
you copy registration, w/out RADF? Or RADF registration adjustment?
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Sharp AR C250A Color Copier Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
