Question about Canon PIXMA MP830 All-In-One InkJet Printer
Alarm continues to flash no jams, cords are where
Alarm continues to flash no jams, cords are where they need to be etc. The error number is not found in manual but it is 6A00 error.
    President:
  • 2,306 Answers
6A00 means the purge assembly is jammed. Look inside to the right where the printhead rests when turned off. Remove any paper scraps. Otherwise you need a new purge unit
QM2-3032-020 around $30 for the part.
Posted on Jul 02, 2009
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
117 people viewed this question
old marine
old marine
