Question about Maytag MFI2568AE Side by Side French Door Refrigerator
We have a Maytag MSD2957AEW side by side fridge and the freezer is working fine but the fridge side is steady at 50 degrees and it is set on 7. What could be going on? Thanks!
My fridge should be colder but the freezer part is working
Posted on Jul 04, 2009
The evaporator coil behind the plastic panels in the back of your freezer are probablye locked up solid with ice. Open the door and let it melt out for 4 hours. It will proably then run but good chance it will do it again. the time to get the testers out!
Posted on Jul 09, 2009
  • 400 Answers
I believe that you may have a refrigerant leak on the fridge side. You will have to have this checked by a technician.
Posted on Jul 02, 2009
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
GSS22JEMC fridge is only 50 degrees on coldest setting. Freezer works fine.
Your fridge 100% depends on the freezer. Most likely you have a defrost system problem (look for icying up on the freezer wall). You can try to defrost it by unplugging it for 24 hours.
GE refrigerator repair orange county, ca
Feb 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
MSD2454GR Side by Side refrigerator- freezer side fine, refrigerator side will not cool below 50 degrees; lots of condensation
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Maytag MSD2454G Side by Side Refrigerator
Fridge and freezer not working on new Maytag, Help!!
at 5 months old don't try to fix it yourself CALL the store where it was purchased or maytag
you may mess up the warranty if you try to fix it yourself
document all of the calls you make to where and who you spoke with at what time
ask for promises in writing have them fax it to you so you have the promise in hand
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
FREEZER WORKS BUT FRIDGE IS 50-55 DRGREES
if all that is ok then you need to check the heater and bi-metal / if it starts frosting up you loose air into the refrig side and the freezer will start going down too / frig side gets tem from freezer ,,,,, i bet you have a bad defrost heater / larry
Nov 29, 2008 | Amana ARSE664BS Side by Side Refrigerator
Maytag MZD2766GEW side-by-side - one side is not cold
WE JUST HAD THAT SAME PROBLEM AND IT WAS THE DEFROST BOARD. $50.00 REPAIR...
Jun 15, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Feb 22, 2008 | GE GSS25LGM Side by Side Refrigerator
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
292 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
