Question about Durabrand Televison & Video
It loads for a while then says either "no disc" or "disk error" no matter what disk is in it
  • 52 Answers
Take it apart and clean the lens that reads the disc with a q tip and nail polish remover
Posted on Jul 02, 2009
When i am loading dvd into player message comes on screen disc format error ?
It's either a non compatible format or the slightest smudge on a disk or disk player will cause an error.....
Feb 27, 2015 | 2006 GMC Yukon Xl Denali
Error 0XC000000C and 0XD000001E and 0XA0000001 how would I fix these errors its on a Aspire 5315-2153 Notebook did have Window Vista as OS I tryed the backup disc I made 1-9 error OXC000000C on disc 7 I...
My 0xc000000c "Restore Failed" prompt seemed to be the result of disk surface damage on the restore disk. After burning the restore disk to a new disk, the restore proceeded normally. Try making a copy of the original restore disk to a known good blank disk.
Jul 20, 2009 | Computers & Internet
''Wrong Disk'' error
KM,
You'll need to check the region code of your player.
Make sure you have no discs in the player, and unplug the unit.
Plug it in and turn it on.
Open, then close the tray (with no disc!)
Press the Setup button, then select Load Setup
Press the Enter
While it it loading, press Menu.
When the box appears with a number, confirm it says 1 (region code 1 = USA). If it doesn't, please change it to 1 using the Up / Down buttons.
Press Enter to accept the change.
Jul 07, 2009 | TruTech DV288B3 DVD Player
I have pinnacle studio plus version 10. I loaded the 1st disk w/o a problem. When prompted to load disk 2 I did and it will NOT load. I reloaded disk 1 again and then tried to load disk 2 and IT WILL NOT...
Have you tried loading disk 2 on it's own with the autorun feature turned off and then exploring the drive to see if you're computer's drive is able to read the disc? If the disc simply isn't loading, the disc is most likley has an error which is preventing the DVD drive from reading it and you'll just simply have to appoach the seller to replace it.
Apr 13, 2009 | Computers & Internet
Single blank disk inserting wont work (Mircoboards PF2)
You may have a disc loading error. To correct this follow these instructions:
Disk Loading error:
If a disc is not loaded correctly, it could cause the out of paper indicator to come on. Press the out of paper button on the interface. The printer will attempt to load another disc. If this does not clear the error, remove the discs from the input bin. Check to see if there are any discs on the belt. Remove any discs that are left on the belt.
Lift the cover and check for any discs on the front part of the printer. Remove any discs found on the belts. Close the cover.
Next, reload the input bin and press the out of paper button. The system will load the next disc and continue printing the remaining discs for that job.
If that doesn't work, and there are no obvious jams in the transport system, I'd call support and see if they can walk you through a fix. They can be reached at:
For technical questions or support issues, please contact Microboards Technology technical support at PH: 952-556-1639, FAX: 952-556-1628, by email at support@microboards.com or on the web at http://www.microboards.net.
Mar 19, 2009 | Microsoft Windows XP Home Edition
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
Soltek sl-k8trpro939, error message BIOS not Loaded,
To clear cmos you'll need to remove the cmos battery from the motherboard for about 5-10 seconds then replace. You need your motherboard disk in order to load the bios. If you do not have this disk then you will need to go to the board manufacturer's website & download the bios. Follow the directions they have at the site to make a bootable disk & then boot from this disk. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Soltek SL-KT600-RL Motherboard
Bad Disc Errors
are they disks you burnt?
Jul 15, 2008 | JVC Televison & Video
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Keeps displaying error cdc
you can try to use a cd lens cleaner CD. Put the lens cleaner in slot 1 and load disk 1 the cleaner shouls be dropped in place and begin to clean the cdrom lens.
Sep 18, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Televison & Video Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
