Question about Nokia 5800 XpressMusic Smartphone
After ending an incoming call, the screen stays black and the phone locks up. The green, white, and red keys stay lit. No response from any buttons, including the power on/off. Have to pull the battery to restart. This is the third or fourth time in the last five or so days this has happened. Did not happen at all prior to this, in several weeks of use. Any ideas?
  • jim45377 Aug 02, 2009
    I was checking for new software updates for this version of the phone and one was available. Installed it and the problem has not occurred in several days hence, and with numerous incoming calls. Perhaps the "bug" was fixed, perhaps the software installed properly as suggested in the posted solution.
    We'll see, either way.
    Guru:
  • 523 Answers
Hi Friend,
This problem occurs,at the time of any software installation if it has not been installed properly it creates this problem.The solution for this issue is as follows,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 1 to 3 Mins.
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Posted on Aug 02, 2009
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Red Message List stays lit solid even when there are no messages.
No, it stays lit because there *are* messages, just not voice mail messages. Press the MESSAGE button and look at the display. Look at what's above soft key #3. If you don't need the information in the first line, use the CLEAR key to erase it.
Carl
Apr 04, 2011 | Panasonic KXDT343 Phone
My touch screen on my nokia 5800 wont work
Press the GREEN + RED + CAMERA buttons all together, then hit the power key. Wait for it to show the handshake and you should get a prompt for pin code and/or lock code. The default lock code is 12345, but it sometimes stays the same after restart.,ALL SETTINGS WILL BE RESET AND HOPEFULLY UR TCHSCREEN WILL WORK..
May 12, 2010 | Nokia 5800 XpressMusic Smartphone
My acer aspire ones screen is just staying black and wont reboot what do i do ?
I have the same problem! I received a response to my email telling me to disconnect adapter and battery, hold the power button 30 minutes, connect ac (make sure it's plugged), turn on, wait 1-7 minutes, then attach battery after windows boots. After several tries, it still hasn't worked. When I turn on the system, my power led stays green, but the hdd indicator is not lit. My battery can still recharge, but the screen is still black, and there is no sound.
Apr 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
LIGHT ON THE SPEAKER BUTTEN STAYS ON
If your speaker button doubles as an in-use-indicator , You most likely have a reverse polarity, This is not usually a problem because the phone will work either way, This only happens with some systems, Check your wall jack for Red and Green wires. The Jack Red Wire should be (Depending on your house wiring) attached to a Red, Blue, or Bluewhite wire and the Green should be attached to a Green, White/Blue stripe, or White/blue striped. Yellow and Black was intended for line 2 but may have been used instead. I hope this helps you
Dec 05, 2009 | General Electric 25982EE3 Twin Phone
Saumsung J706 and the screen is black
you need to bring it to a repair shop. it is most likely a problem with a part which they call Flex Cable...
Nov 09, 2009 | Cell Phones
Black screen
This problem has happened to me before turn the gps unit over and clean off the gold colored conductors on the bottom take a paper clip and touch the 1st and 4th pins together this resets the unit be sure it is the 1st and 4th pins on the opposite side of the little power connector though.
Jun 26, 2008 | Mitac Mio C320 Car GPS Receiver
Razr- turning on camera makes screen turn black but keypad stays lit
the easiest thing tpo do here is take it to a professional but if you want to try updating your software off the Motorola website. (this require a data cable or bluetooth in your computer) This fixes a lot of software problems with the razor. If this doesn't work then you will have to reflash your Firmware which is like the Windows Xp of the phone. This does require a professional as it can destroy the phone
Jul 05, 2007 | Motorola Mobility RAZR V3
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Nokia 5800 XpressMusic Smartphone Logo
93 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
