Trouble with Air Con Unit
We have just had one of your units fitted in our office and the town had a powercut on tuesday and the unit no longer works
In you handbook it says why the unit may not work but doesnt give advice on how to restart the unit
the operation indicator and timer indicator are flashing constantly
Regards Phil Whitehead
  • 3 more comments
  • Anonymous Nov 19, 2007
    Air conditioner is switched off but the operation indicator and timer indicator lights are constantly flashing.
  • Jongers Dec 13, 2007
    My remote control does not work on the air con at all, but there is a green light constantly flashing in the bottom right corner of the unit.
  • Klik2Rik May 07, 2008
    Unit cycles off and on leaving the "timer" and "fan" lights blinking.
    I've pulled and reinstalled the service disconnect, but get the same results.
  • don carlo May 13, 2008
    The operation and timer LEDs blink when i turn on the A/C. The timer has not been set at all. I have reset the power to the indoor unit, reset the breakers and reset the remote control all without any difference in operation.
  • mralexgray May 21, 2009
    I lost power to apartment, now LA121CNP will not power back on from indoor unit button, or via remote.
  • 236 Answers
Try to run the unit by pressing the manual button in the indoor, if it works then try the remote control if it will respond. But if not try to unplug the power supply or "off" the circuit breaker and "on" again and try the remote control if it works then the remote is ok if not may be the receiver is defective.
Posted on Dec 31, 2007
What does error code po5 on a sanyo cassette air con mean
P05-Current value sent from MDC on outdoor unit control PCB is low. No AC power input for 3
minutes or longer: pre-trip - 5
1. Check R/S/T power.
2. Check inverter control PCB.
3. Check outdoor unit control
Feb 11, 2011 | Sanyo Heating & Cooling
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Hi On our portable DeLonghi air con, we have
Temp setting is very low. Raise it. And also service your unit frequently.
Dec 24, 2010 | DeLonghi PAC C100 Air Conditioner
Air con unit saying 'C6"
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
all the best
Jul 05, 2010 | LG LSC183VMA Split System Air Conditioner
Air con indoor unit is flashing 6 times out door is off
Please specify the make and model of your unit.
If this is a LG inverter model.
The six flashes of the indoor unit light indicates a CH 06 alarm.
This alarm state indicates that the indoor unit pipe temperature sensor has measured a temperature out of range or the unit is protecting itself from this low temp state. Indoor unit coil temperature to low. Should it have reached a temperature of -5°C for longer that 30sec it will switch the machine off.
It could indicate that the unit refrigerant charge is too low or the sensor has gone out of calibration.
It should measure 5kΩ @ 25°C
Mar 16, 2010 | LG Heating & Cooling
I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Jul 29, 2009 | Danby DPAC8020 Air Conditioner
Electra remote wont work with electra air con. should have a sticker under the indoor unit head unit or on the side.
Jun 10, 2009 | Heating & Cooling
Air Con failure Audi A6
if its a climatronic head unit and there is a fault the head unit sometimes flashes to tell you there is a fault,diagnostic equipment should be able to pin point your problem
Nov 15, 2008 | 2005 Audi A6
Dometic roof top air-con trouble
1.check wiring of unit.
2.check drain tray.
3.check u band of drain pipe.
Feb 16, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
608 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
