Question about Jenn-Air JCD2389G Side by Side Refrigerator
I have a side by side and my freezer is freezing up on the bottom. Don't know what to do with it.
  • 400 Answers
Three things can cause this. One. The fanmotor is bad. Two, your defrost element is bad. Three, your control pc board is bad which means it is not telling the fridge to cycle when it has reached temperature. Hope this helps.
Posted on Jul 02, 2009
Water on freezer bottom
may i asked what freezer or refrigerator do you have? is it a non- freeze or an ordinary freezer?... if it is a Non- freeze one try unloading stuffs that you don't need because it just don't help and it increases the "lowside" if you know what i mean and the motor as well. don't overload any of it..
Jun 24, 2012 | Refrigerators
20 cu ft freezer top 1 foot things don't freeze completely. Bottom 1 ft things don't freeze completely. But the middle 18 cu ft its frozen.
Gas is low, also check for air flow obstruction, this may fix it,,also seals at the base of the door....Russ
Aug 22, 2011 | Frigidaire Freezers
I have a Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GR that seems to have a defrosting problem. I submitted a question and after looking at the freezer the inside coils...
In the freezer compartment, there is a heater tube that stops the freezer from freezing up. It is probably blown, and you need a replacement heater tube.
Aug 08, 2011 | Refrigerators
Water is leaking inside the freezer and collecting at the bottom of the freezer. It eventually freezes down at the bottom of the freezer.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
If this was helpful please rate me.
Don't forget to check the icemaker for leakage, also
IMUFO2
Leo Ponder
imufo2@sbcglobal.net
Jul 26, 2011 | Kenmore Side by Side Refrigerator
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Kenmore regrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
    Mike
Aug 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
Freezer freezes at top but not at bottom
  1. first make sure the fan is coming on in the freezer. if it is not working then the fan motor may be bad or obstructed.
  2. then Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
Mike
Aug 01, 2008 | GE ZIS420NR Side by Side Refrigerator
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jenn-Air JCD2389G Side by Side Refrigerator Logo
94 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
