Bought a brand new battery for the expedition, changed it and now it won't start at all.
SOURCE: I am having a no start no crank problem with my
I am experiencing the same issue with my 2001 expeditiion. Just curious... after the vehicle has been running hot for a while and you park and shut the motor, then it won't restart? Unless I wait for approx 1/2 hour when motor has cooled then it starts up. I have had mechanics check the fuel line and the fuel seems to "vapor lock". The fuel pump may need repaired/replaced. I am not experiencing and electrical issue. This is a fuel intake issue.
SOURCE: My 1998 Ford Expedition won't start. I changed
Improve the Fixya.com experience for everyone by voting!
This is how your problem is solved in my shop. Out of the box, I'd say that you have a problem with the fuel management system. However, there's a good chance that it's something simple and inexpensive like a clogged fuel filter or water in the fuel tank.
My second area of concern would be the manifold pressure sensor which is loctated under the hood, center, rear engine area, above valve cover, mounted in bracket. However, you must remember that these nothing more than starting points and not guaranteed solutions.
First a little background for your edification. You may be aware of all this but we've never done business before and all assumptions are off the table.
For an engine - make that any engine and irrespective of manufacturer - to run, you need three things to happen inside the engine, compression, fuel and ignition, without any one of these components the engine will not run.
Whenever your engine cranks but does not start, runs rough, staggers, sags or cuts off, follow this Troubleshooting Guide. Some of these steps require a code scanner. They are costly but AutoZone will loan you one for FREE.
Most vehicles operate by the same principle; basic troubleshooting procedures apply to most cars.
The reason we repair non-related codes after the engine is running is because sometime false codes can be triggered by the engine not running. Once the engine is running again the code present might cycle and turn itself off. You might say "if the engine doesn't run shouldn't it have a trouble code?" Sometimes conditions occur that will not be detected by the computer, example: if the fuel pump fails the computer cannot detect the failure, so the engine doesn't start and the computer thinks everything is okay with no codes. If no trouble codes are present proceed to the next step.
If you have trouble using the code scanner or interpreting the codes click on the following link and use my access code (carrepair): Free Automotive Repair information for Users of a Code Scanner www.repairpath.com
All the best
Ben
SOURCE: my ford expedition won't start i change the fuel
If it a diesel then you must be aware that when changing a filter and pump they must be full of fuel, otherwise it won't **** the fuel into the engine.
SOURCE: 2002 ford taurus won't start
Sounds like your not getting any fuel..Listen for the fuel pump,by removing gas cap and put your ear up to it..cycle the key without starting it and listen for the pump..sometimes you can beat on the bottom of the tank and it will jarr the pump and it will start running again..Not a fix but a conformation
