Motherboards
Problem for ASUS Motherboards
Generic problem for all ASUS Motherboards
ASUS A7N8X-E Deluxe Motherboard sup...
By mechabh on Jul 02, 2009
ASUS A7N8X-E Deluxe Motherboard supports 1TB SATA2 HDD?
Best Solution
posted on Jul 02, 2009
Very Helpful)
ser71
Rank: Guru
Rating: 86%, 659 votes
1) Grab a blank floppy, and a computer running Windows with a floppy drive.
2) Download C18E1013.zip (A7N8X-E Deluxe Latest BIOS, from Asus), AWDFLASH (Also from Asus), the latest Silicon Image SATARAID BIOS (from Silicon Image), and CBROM 2.15 (Alternative CBROM 2.15 download link)
3) Extract all the contents of everything into an easily accessible folder, preferably something like C:\bios
4) Make sure you have no other folders in this new folder. Everything must be within C:\bios, so for example there shouldn't be anything in C:\bios\BIO-003112\
5) Open a command prompt (Start -> Run, type "cmd" and hit enter, without the quotes)
6) Navigate to the folder you just created using the command "cd" (For example, if you used the folder I suggested above, you would type "cd C:\bios", without the quotes, and hit enter)
7) Now type "cbrom215 c18e1013.bin /pci 4284.bin" without quotes, and hit enter. This will take the latest BIOS for your motherboard, and merge the new SATARAID BIOS into it.
8) To make sure everything went correctly, type "cbrom215 c18e1013.bin /D". This will show a list of the modules in the BIOS. At the bottom should be a line with PCI(A), and should have "4284.bin" at the right end of that line.
9) Now put the blank floppy into the computer with the floppy drive.
10) Open My Computer, right click on the floppy drive (probably A:), and select "Format"
11) The formatting window should pop up. Check the box labeled "Create an MS-DOS startup disc" (which should disable all the other options), and click Start.
12) Click OK and close the format utility when the process completes.
13) Copy the modified BIOS file c18e1013.bin and the file AWDFLASH.EXE to the floppy disc (simply a drag and drop).
14) Close everything on the computer with the A7N8X-E Deluxe motherboard and reboot it. Make sure the computer is set to boot to the floppy drive, and that you have put the floppy in the drive.
15) Type the command "awdflash c18e1013.bin /py /sn" once you get to the "A:" prompt.
16) Press enter to confirm that you wish to overwrite the current BIOS.
17) Wait.
18) Once it says it is complete, remove the floppy, press F1 (as instructed), then reboot the machine (which should happen automatically once you press F1). Now the computer should detect the 1TB drive upon booting.
Was this helpful?
Yes
No
6 people thought this was helpful
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS... (More)
Answer
compaq presario mother board, what should I replace it with
Answer
In reply to some of your postings, I have a Northgate computer that recently bit the dust. I do... (More)
Answer
processor fan wont come on. The fan does work, I tested it, but no fan I attach to the motherboard... (More)
Answer
I've mistakenly changed the boot order for my video card. My video card is a PCI-Slot nVidia card... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , OH
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
